WannesT
NTP on raspberry
Tue May 09, 2017 5:44 pm
I'm building an application that collects data from sensors. Every x seconds, the data are send to my website, to store them in a mysql database.
I am now looking for a solution to send the correct date and time together with the data.
Can I realize this by regurarly sync a clock via ntp? How can this be done? I am using C# for my app.
Txs!
Re: NTP on raspberry
Tue May 09, 2017 8:22 pm
Are you doing it with WinIoT or C# with Mono on Raspbian.
Raspbian has NTP built-in, no mucking about needed.
WannesT
Wed May 10, 2017 3:11 pm
hello, txs for the reply!
I am using win IOT indeed.
grz
asandford
Wed May 10, 2017 11:14 pm
DougieLawson wrote: Raspbian has NTP built-in, no mucking about needed.
Which is somewhat different to Debian 8 (jessie) which doesn't, it uses systemd-timesyncd.
I don't wish to start a discussion on the relative merits of either, but find it odd that time sync is not borged into the systemd collective in Raspbian.
pauldy
Wed May 10, 2017 11:46 pm
It should be built into win iot as well if it isn't working you might use power shell to see if you can ping the time servers or you can reset them using something like.
w32tm /config /syncfromflags:manual /manualpeerlist:”mytimeserver1 mytimeserver2"
Return to “Windows 10 for IoT”
