Disable Wifi on Raspberry Pi 3
Posted: Wed May 03, 2017 7:08 pm
by Avalanchis
Does anyone know how to disable the Wi-Fi interface on Windows 10 IoT for the Raspberry Pi 3?
I've tried the following from a command prompt, but it does not seem to work:
netsh interface set interface name="Wi-Fi" admin=DISABLED
Thanks!
Alan
Re: Disable Wifi on Raspberry Pi 3
Posted: Thu May 04, 2017 1:48 pm
by Clanzer
Give Powershell a go
Right click on pictures and choose open in new tab to get a bigger view of them.
Run up IOT Dashboard and under Devices, Right click on your Raspberry Pi and choose Launch Powershell.
Put in the Admin password when prompted.
It can take a few seconds to connect, but when it does you should get a command prompt.
The to list your network interface type
Get-Netadapter
Then to Disable the Wi-Fi interface
Disable-Netadapter Wi-Fi
The do another Get to check if it is disabled.
Should stay disabled after a reboot also.
Hope this helps.
Cheers
Sean
Posted: Thu May 04, 2017 1:59 pm
by Avalanchis
That worked perfectly!
Thank you so much!
Alan
Posted: Thu Jan 24, 2019 11:29 am
by aldesa
I need also to disable the WiFi on my Rasperry Pi Model B.
Unfortunately, always Powershell hangs when I try to connect to my Raspberry Pi (S.O. 10.0.17763.107), so I am not able to try this solution.
I see two possible solutions:
1- using SSH: which commands to use in order to disable wifi ?
2- succeeding in using Powershell: why Powershell hangs ?
Thanks in advance for your help
