TheLoadedRogue
IoT CM3
Sat Jan 28, 2017 6:02 pm
Hi all,
Will Windows IoT work on the CM3 or does it have to be CM3Lite with an 8GB+ eMMc?
Want to know before I buy one.
Re: IoT CM3
Sat Jan 28, 2017 6:19 pm
TheLoadedRogue wrote:Hi all,
Windows 10 IoT Core does not list CM3 as a Supported Device, maybe Microsoft can inform you if they have future releases of their Operating System suitable for the CM3 ???
Retired disgracefully.....
W. H. Heydt
Re: IoT CM3
Sun Jan 29, 2017 12:57 am
What does MS show as the system requirements?
TheLoadedRogue
Re: IoT CM3
Mon Jan 30, 2017 10:19 am
W. H. Heydt wrote:What does MS show as the system requirements?
This is what has confused me, as far as I was aware IoT required a minimum of 8GB Storage.
Presuming this means IoT needs the CM3Lite as it allows a custom storage media, you would then need to wire an SD card (port) to the SD0 pins?
Or is it possible to wire a SD card port to the eMMc pins?
Re: IoT CM3
Mon Jan 30, 2017 10:44 am
https://www.raspberrypi.org/documentati ... T-V1_0.pdf
The CM3 needs an updated Kernel / Firmware AFAIAA, have MS updated Windows 10 IoT Core ??
https://social.msdn.microsoft.com/forum ... WindowsIoT
Re: IoT CM3
Mon Jan 30, 2017 12:19 pm
8GB for an IoT device? That's expensive.....they'll need to reduce that if they want to get decent take up.
