"Windows failed to start"
Posted: Fri Dec 30, 2016 6:11 pm
by zdf
See the attached image.
- Brand new RPi3.
- Works fine with the Raspbian & OSMC.
- Card flashed many times with the same result. I have also tried an insider version.
- The board is resetting itself after a while, for several times before finally booting into Windows.
Any thoughts?
Thank you.
Re: "Windows failed to start"
Posted: Sat Dec 31, 2016 3:48 am
by stonelance
I get the same thing on RPi3 with Win 10 IoT 14931. If i leave it on that screen it will eventually reboot after a few minutes and usually boots properly after that. What SD card are you using?
Posted: Sat Dec 31, 2016 7:33 pm
by zdf
@stonelance
Yes, it was the card. An otherwise fine card; my cameras had not problems with it. It is a 64GB, class 10 card. I have changed it with a 4GB, class 4 and now everything is fine.
It would be nice to know what the actual cause is.
Thank you.
