can not start windows 10 iot!
Posted: Sat Nov 26, 2016 10:19 pm
by mickel2009
I bought a sony card uhs-i sr-8uya 8 GB. Windows 10 iot is not loaded if I start with noobs. If I start from the windows 10 iot dashboard colored square appears. Can my raspberry pi is faulty? May be i buy another raspberry?
I write the image using the PC. All the instructions I reviewed. There is written in great detail, and even have screenshots, but they do it well, but I don`t can. Sorry for my bad english
Add another important information : led Green gives 5 long and three short. Does this mean 8 solution? So how about tanning duration led error codes not specified
Re: can not start windows 10 iot!
Posted: Sun Nov 27, 2016 6:19 am
by DougieLawson
Those flashes mean you've failed to create your NOOBS card correctly.
https://www.raspberrypi.org/help/videos/#noobs-setup
Re: не могу запустить windows 10 iot!
Posted: Sun Nov 27, 2016 12:52 pm
by mickel2009
may be I need update firmware (bootcode.bin/start.elf)?
Posted: Sun Nov 27, 2016 1:04 pm
by DougieLawson
mickel2009 wrote:may be I need update firmware (bootcode.bin/start.elf)?
NO. You need to wipe your NOOBS card and build it correctly.
Unzip the NOOBS zip file, copy the contents of the folder where you've unzipped it to the root directory on the card.
Done correctly NOOBS boots to the installer menu without any problems as long as your RPi and your TV are connected and compatible.
You will need to wire your RPi to your network to get WIN10 IoT as an installer option.
Posted: Thu Dec 01, 2016 9:00 am
by mickel2009
https://youtu.be/DBAVrfBrM3M
Video answer
Play Start at 0:00
I try to install different operating systems
