Aymeeeric
[RESOLVED] Html form POST
Mon Jul 04, 2016 7:16 am
Hi !
I have to make an automatic post to a web form with my IoT application.
It's a simple web form (only few parameters) but one of them is a file (audio)...
How to do this ? Is it possible with the HttpClient object ?
Hope you can help me...
Thanks in advance !
Aymeeeric
Re: Html form POST
Mon Jul 04, 2016 8:42 am
Ok, so after many tries, here is the solution :
 // Upload :
using (var client = new HttpClient())
	using (var content = new MultipartFormDataContent())
		var values = new[]
			// Form data :
			new KeyValuePair<string, string>("audio[audio_id]",     "DB_"),
			new KeyValuePair<string, string>("audio[type_report]",  "TEST"),
		foreach (var keyValuePair in values)
			content.Add(new StringContent(keyValuePair.Value), keyValuePair.Key);
		// File (form-data too) :
		var fileContent = new ByteArrayContent(System.IO.File.ReadAllBytes(file.Path));
		fileContent.Headers.ContentDisposition = new ContentDispositionHeaderValue("form-data")
			Name = "audio[audioURL]",
			FileName = fileName
		content.Add(fileContent);
		var requestUri = @"/global.php/audio/create";
		var response = client.PostAsync(requestUri, content).Result;
		var contents = response.Content.ReadAsStringAsync();
Return to “Windows 10 for IoT”
