chakotay65
black screen
Fri Jun 10, 2016 5:23 pm
I guys, kind of new to all this. Bought a pi 2B and I believe the "official" LCD 7 inch touch screen (element14). Under raspbian everything works fine. Under Windows 10 IoT the LCD stays black while connecting my monitor to the HDMI gives a good picture. Where can I start to look for problems? Maybe I should add that the version of Windows is listed as 10.0.10586.218
tsaG
Re: black screen
Sat Jun 11, 2016 1:59 pm
Try installing the Insider preview of Windows (14342)
chakotay65
Re: black screen
Sat Jun 11, 2016 3:23 pm
thanks, that did the trick!
mar332
Re: black screen
Tue Jun 28, 2016 9:38 am
chakotay65 wrote:I guys, kind of new to all this. Bought a pi 2B and I believe the "official" LCD 7 inch touch screen (element14). Under raspbian everything works fine. Under Windows 10 IoT the LCD stays black while connecting my monitor to the HDMI gives a good picture. Where can I start to look for problems? Maybe I should add that the version of Windows is listed as 10.0.10586.218
Your touchscreen works on Windows IOT ?
tsaG
Re: black screen
Tue Jun 28, 2016 7:44 pm
Yes it works. The only thing that doesn't work is using the display in portrait mode. But I think thats a general Pi issue (since there is also no fix in unix yet, only a workaround)
mar332
Re: black screen
Wed Jun 29, 2016 6:41 am
Sum up:
- I should sing up and installing the Insider preview of Windows (14342)
- configure the file config.txt
that's all ?
and should work on my PI 2B ???
tsaG
Re: black screen
Wed Jun 29, 2016 12:37 pm
Yes
Return to “Windows 10 for IoT”
