SainSmart 7inch touchscreen
Posted: Sun May 01, 2016 9:17 am
by huras
Hi all, I have bought the SainSmart touchscreen http://www.sainsmart.com/raspberry-pi/r ... a-2av.html but it doesn't works on Windows IoT.
The touchscreen use this ISB controller http://pdf1.alldatasheet.com/datasheet- ... 3723C.html.
There is a way to make things works?
In alternative, where can I start to write a WDF driver myself?
Re: SainSmart 7inch touchscreen
Posted: Sun May 01, 2016 11:31 am
by fruitoftheloom
huras wrote:Hi all, I have bought the SainSmart touchscreen http://www.sainsmart.com/raspberry-pi/r ... a-2av.html but it doesn't works on Windows IoT.
Well it is not listed on the compatible hardware listing:
https://developer.microsoft.com/en-us/w ... rfaces.htm
Therefore you will need to write a Universal Driver:
https://developer.microsoft.com/en-us/w ... /driverlab
If you can navigate around the MS Website there is a wealth of information, as well as the Forum here:
viewforum.php?f=105
Posted: Wed May 04, 2016 7:18 am
by mar332
Try change config.txt. Clear old txt and add this :
gpu_mem=32                  # set ARM to 480Mb DRAM, VC to 32Mb DRAM
framebuffer_ignore_alpha=1  # Ignore the alpha channel for Windows.
framebuffer_swap=1          # Set the frame buffer to be Windows BGR compatible.
disable_overscan=1          # Disable overscan
init_uart_clock=16000000    # Set UART clock to 16Mhz
# set current over USB to 1.2A
max_usb_current=1
# overscan to adjust image position
overscan_left=0
overscan_right=0
overscan_top=0
overscan_bottom=0
# HDMI config
hdmi_drive=1
hdmi_ignore_edid=0xa5000080
hdmi_group=2
hdmi_mode=87
# 800x600 display
hdmi_cvt=800 600 60 3 0 0 0
