W2K
WiFi Direct unstable
Sun Feb 07, 2016 11:18 pm
I am trying to make RPI Windows IoT Core creating its own WiFi using WifiDirect API. I use IoTOnboarding example as reference.
As the publisher starts listening there is no problem. Devices can connect to hosted network get the IP etc. The problem occurs after few seconds / minutes. Some devices lose connections, some new are unable to connect again (in most cases they are stuck on 'getting ip'). This is annoying because they I can't figure out if it is my problem or bugs in windows IoT Core.
I have tow WiFi dongles (exchanging them to test) one from TpLINK and one official RPI dongle both are claimed to be supported and on both I have exactly the same effect.
Is there something I'm missing ? Or the wifi direct tends to have bugs ?
Cheers,
Tomasz Chacuk
haroldpulcher
Re: WiFi Direct unstable
Thu Feb 25, 2016 11:11 pm
Are you putting the Wifi dongles in the top row?
If so there was a known bug that they are flakey there. Don't know why just that they are.
Try putting in the bottom row and see if you have a different experience.
I didn't believe them either till I tried. :)
Harold
Return to “Windows 10 for IoT”
