informed
UDP not being recieved
Thu Jan 14, 2016 7:15 am
In my Raspberry Pi2 device I have an app that broadcasts its own IP address (on a timer) to the rest of my network this that code:
public static async Task SendMessage(string message, int port)
try
var socket = new DatagramSocket();
//socket.MessageReceived += SocketOnMessageReceived;
using (var stream = await socket.GetOutputStreamAsync(new HostName("255.255.255.255"), port.ToString()))
using (var writer = new DataWriter(stream))
var data = Encoding.UTF8.GetBytes(message);
writer.WriteBytes(data);
await writer.StoreAsync();
catch (Exception ex)
System.Diagnostics.Debug.WriteLine(ex, "SocketClient.InitSoSendcketClient");
On my client app it will pick it up via this code:
public static void Start()
UdpClient udpServer = new UdpClient(80);
var remoteEP = new IPEndPoint(IPAddress.Any, 80);
while (true)
var data = udpServer.Receive(ref remoteEP);
var requestCommand = Uri.UnescapeDataString(Encoding.UTF8.GetString(data, 0, data.Length));
var message = JsonConvert.DeserializeObject<Model.NotifyMessage>(requestCommand);
Shared.RASPBERRY_PI_IP_ADDRESS = message.IP;
Console.WriteLine(message.IP);
This used to work but does not do so now. I had upgraded the Raspberry PI2 'OS' to the latest but I seem to recall it still worked for a while.
It just stopped working yesterday for some reason. I have set the breakpoints and I know the IP address is being sent from the PI it is just not being recieved for some reason.
Is it a virus? Is it a firewall issue on the PI (if so how do I let it through?)?
I can still browse to the home page OK and my Windows IoT Core Watcher still sees the device
ricl
Re: UDP not being recieved
Thu Jan 14, 2016 8:50 am
Make sure you have opened the relevant port in the Pi's Firewall. It is in the FAQ.
ricl : F/gamma = ma : Law ii(a) : https://climatedatablog.wordpress.com/2016/01/02/an-energy-challenge-2016/ #AnEnergyChallenge2016
haroulis
Thu Jul 13, 2017 4:08 pm
informed wrote:Hi,
try
while (true)
What language is your code? did you manage to make it work?
KyysmaWen
Thu Aug 03, 2017 2:22 pm
hers your problem
try un-checking some codecs
tools>options>compatibility tab
