RobLatour
get and change audio volume on windows iot from .net code
Sun Jan 10, 2016 3:59 pm
I can't seem to figure out how to get or change, from a .NET program, the audio volume level on a raspberry pi running windows IOT.
I can see how to change it by signing onto the device as an administrator (via the web browser interface) - its just a slider on the 'audio' tab - but I can't figure out how to do it from a running app created using .net.
If you know how to do this, I would very much appreciate you sharing how.
ricl
Re: get and change audio volume on windows iot from .net cod
Sun Jan 10, 2016 5:49 pm
A lot changed in 10586 with the additional REST api.
The REST api. is all documented in a json on the Pi.
There are, of course, ways to hook up to the various underlying functions from both C and UWP.
Try the UWP Audio samples on Github
ricl : F/gamma = ma : Law ii(a) : https://climatedatablog.wordpress.com/2016/01/02/an-energy-challenge-2016/ #AnEnergyChallenge2016
RobLatour
Sun Jan 10, 2016 9:33 pm
Thanks - I've been looking thru this for the last couple hours, but can't figure out what url to post to.
I have figured out how to sign on to the raspberry using a httpclient, but not what url to use to set the desired volume level.
Here is what I have so far:
Imports System.Net.Http
Imports System.Net.Http.Headers
Imports System.Text
Private Async Sub SetVolume(ByVal volume As Int32)
        Const uri As String = "http://minwinpc:8080/AudioControl.htm"
        Try
            Using client = New HttpClient()
                Dim byteArray = Encoding.ASCII.GetBytes("Administrator:xxxx")
                Dim header = New AuthenticationHeaderValue("Basic", Convert.ToBase64String(byteArray))
                client.DefaultRequestHeaders.Authorization = header
                Dim response As HttpResponseMessage = Await client.PostAsync(uri, Nothing)
                response.EnsureSuccessStatusCode()
                Dim responseBody As String = Await response.Content.ReadAsStringAsync()
                Debug.WriteLine(responseBody)
            End Using
        Catch ex As Exception
            Debug.WriteLine(ex.ToString)
        End Try
    End Sub
It seems to be related to audio.controls.js but I just can't connect all the dots ...
Do I only have to post to one url??
Any further help would be appreciated.
ricl
Sun Jan 10, 2016 9:42 pm
{C:\Windows 10 IoT Raspberry pi\FileSystem 10586\}c:\Windows\WebManagement\www\default\js\RestDocumentation.json
ricl
Sun Jan 10, 2016 9:46 pm
"Imports System.Net.Http
Imports System.Net.Http.Headers"
Those are not what you seek, try the Windows..... ones in the FAQ
RobLatour
Mon Jan 11, 2016 1:46 am
thanks - I switched to using Windows.Web.Http but I still can't figure out what url to use.
Also c:\Windows\WebManagement\www\default\js\RestDocumentation.json makes no reference at all to audio - that seems to be in c:\Windows\WebManagement\www\iot\js\iot.rest.js - in which there is a function called setRenderAudioVolume (which I suspect is what I am after) - but I still cant figure out how to invoke it.
ricl
Mon Jan 11, 2016 6:52 am
See the REST C# examples in the FAQ. Then add Administrator and password as required to the code there. The url should contain the web management REST api values the same as the Desktop Browser
ricl
Mon Jan 11, 2016 6:54 am
The Jason defines (because of other docs requirement throughout MS) what the service does.
It interacts with the js files on the PI to drive the REST as required.
Helps if you read javascript to see what exactly is going on. Documentation by example is documentation none the less.
        public static async Task<JsonObject> GetRESTAsync(string uri)
            try
                PasswordVault vault = new PasswordVault();
                IReadOnlyList<PasswordCredential> credentialList = vault.FindAllByResource(ADMIN_USER);
                if (credentialList != null
                    && credentialList.Count > 0)
                    PasswordCredential credential = credentialList[0];
                    credential.RetrievePassword();
                    SystemUtils.Log("Utils:", "GetRESTAsync: " + uri);
                HttpClient httpClient = new HttpClient();
                httpClient.DefaultRequestHeaders.Accept.Add(new HttpMediaTypeWithQualityHeaderValue("application/json"));
                httpClient.DefaultRequestHeaders.Authorization =
                    new HttpCredentialsHeaderValue("Basic", Convert.ToBase64String(Encoding.ASCII.GetBytes(string.Format("{0}:{1}", credential.UserName, credential.Password))));
                    string content = await httpClient.GetStringAsync(new Uri("http://" + host + ":8080/" + uri));
                    SystemUtils.Log("Utils:", "GetRESTAsync returned");
                return await Task.Run(() => JsonObject.Parse(content));
            catch (Exception ex)
                SystemUtils.Log("Exception:", "GetRESTAsync: " + ex.ToString());
            return null;
        public static async Task<bool> PostRESTAsync(string uri)
            try
                        new Windows.Web.Http.Headers.HttpCredentialsHeaderValue("Basic", Convert.ToBase64String(Encoding.ASCII.GetBytes(string.Format("{0}:{1}", credential.UserName, credential.Password))));
                    HttpResponseMessage response = await httpClient.PostAsync(new Uri("http://" + host + ":8080/" + uri), null);
                    response.EnsureSuccessStatusCode();
                    return true;
                SystemUtils.Log("Exception:", "PostRESTAsync: " + ex.ToString());
            return false;
RobLatour
Tue Jan 12, 2016 3:55 am
Thanks but I still do not see what to use as the uri.
For example say I want to change the audio volume to 75 (out of 100).
In the line from your code above
what do value to I set the variable uri to?
ricl
Tue Jan 12, 2016 8:39 am
exxxample usage (see json for other urls)
            static string host = "localhost";
            JsonObject res = await SystemUtils.GetRESTAsync("api/os/info");
RobLatour
Thu Jan 14, 2016 3:52 am
ok thank you I am half way there - I can now get the sound volume value by using the following uri
api/iot/audio/listdevices
however, I still can't figure out how to change the volume level
I figure the uri will be:
api/iot/audio/setrendervolume
but I can't get the post code to work, I am using:
Dim response As Windows.Web.Http.HttpResponseMessage = Await httpClient.PostAsync(New Uri(Convert.ToString("http://localhost:8080/") & uri), Nothing)
I have tried, an example,
api/iot/audio/setrendervolume?75
as the uri
also just
as the uri - but I can't then figure how to pass the parm value
I've tried
Dim response As Windows.Web.Http.HttpResponseMessage = Await httpClient.PostAsync(New Uri(Convert.ToString("http://localhost:8080/") & uri), content)
where I've tried everyway I can think up and look up to populate content, but to no avail.
Can you help me with this last piece?
ricl
Thu Jan 14, 2016 8:49 am
Probably not. But if you can find Network Monitor (MS) or other network trace application then it is a small matter of doing something, capturing the traffic and having a look at how the Web UI works :-)
RobLatour
Thu Jan 14, 2016 11:50 am
thanks for your help all the same
RobLatour
Sat Jan 16, 2016 3:13 am
After many trials and tribulations I found the following url will return an 'OK' response:
http://localhost:8080/api/iot/audio/setrendervolume?rendervolume=75.5;
problem is that it doesn't do anything, that is to say the volume level is not changing.
I am using the administrator's credentials with the post.
If anyone has any idea what else may be required I'd be appreciative.
RobLatour
Sat Jan 16, 2016 1:56 pm
OK - I found the solution. I will do some dishes, have a coffee, clean up the code and post it here a little later for others.
RobLatour
Sat Jan 16, 2016 5:07 pm
Below you will find the vb.net code to get and set the audio volume level on the Raspberry PI.
It has been written to be flexible enough to work with some tweaking with the iot rest in general.
api strings and parm value names can be found in the following file on your Raspberry:
c$\Windows\WebManagement\www\iot\js\iot.rest.js
(you get to it by starting the Windows IOT Core Watcher, right clicking on line showing your Raspberry, and selecting 'Open Network Share')
For example, for setting the audio volume, in the file c$\Windows\WebManagement\www\iot\js\iot.rest.js there are some lines that read:
function setRenderAudioVolume(renderVolume) {
        var params = { rendervolume: window.btoa(renderVolume) };
        return this.httpPostExpect200("/api/iot/audio/setrendervolume?" + $.param(params));
Form the above the following is important:
the parm value name which is rendervolume as is shown in the part that reads var params = { rendervolume:
and
the api string which is shown as "/api/iot/audio/setrendervolume?"
Special thanks to 'ricl' for pointing me in the right directions over the last week.
Hope this will be of help to you.
The code below requires that you first add, via NuGet, the Newtonsoft.Json package.
Imports Windows.Data.Json
Imports System.Text
Imports Windows.Security.Credentials
Imports Windows.Web.Http.Headers
Imports Newtonsoft.Json
    Private Async Sub RaspberryMainPage_Loaded(sender As Object, e As RoutedEventArgs) Handles Me.Loaded
        ' Save the Raspberry's signon user id and password
        ' this only needs to be done once unless the application name, user id or password change
        CreateAVaultEntry("Administrator", "[email protected]")
        ' Get the current audio volume
        Dim CurrentAudioVolume As Decimal = Await GetRaspberryAudioVolume()
        Debug.WriteLine("Current audio volume is " & CurrentAudioVolume.ToString)
        ' Set the audio volume
        Dim NewAudioVolume As Decimal = 55.5
        If Await SetRaspberryAudioVolume(NewAudioVolume) Then
            Debug.WriteLine("Audio volume set succeeded.")
        Else
            Debug.WriteLine("Audio volume set failed.")
        End If
    End Sub
#Region "User ID and Password"
    Private Sub CreateAVaultEntry(ByVal UserName As String, ByVal Password As String)
        Dim MyAppName As String = Application.Current.ToString
        Dim Credential As New PasswordCredential(MyAppName, UserName, Password)
        Dim PasswordVault As New PasswordVault
        PasswordVault.Add(Credential)
    End Sub
#End Region
#Region "Get and Set the Audio Volume on the Pi"
    Private Async Function GetRaspberryAudioVolume() As Task(Of Decimal)
        Dim ReturnValue As Decimal = 0
        Dim RestResults As JsonObject = Await GetRESTAsync("api/iot/audio/listdevices")
        Dim KeyPairDictionary As Dictionary(Of String, String) = JsonConvert.DeserializeObject(Of Dictionary(Of String, String))(RestResults.ToString)
        If KeyPairDictionary.ContainsKey("RenderVolume") Then
            ReturnValue = CType(KeyPairDictionary("RenderVolume"), Decimal)
        Else
            Debug.WriteLine("Failed to get Raspberry audio volume")
        End If
        Return ReturnValue
    End Function
    Private Async Function SetRaspberryAudioVolume(ByVal NewAudioVolume As Decimal) As Task(Of Boolean)
        Return Await PostRESTAsync("api/iot/audio/setrendervolume?rendervolume=", NewAudioVolume.ToString)
    End Function
    Public Shared Async Function GetRESTAsync(uri As String) As Task(Of JsonObject)
        ' examples:
        ' uri = "api/os/info" .... returns .... {"ComputerName" : "minwinpc", "Language" : "en-us", "OsEdition" : "IoTUAP", "OsVersion" : "10586.0.armfre.th2_release.151029-1700", "Platform" : "Raspberry Pi 2 Model B"}
        ' uri = "api/iot/audio/listdevices" .... returns ... {"RenderName" : "Speakers (Raspberry Pi 2 audio)", "RenderVolume" : "80.0"}
        ' uri = "api/iot/device/DateTime"  .... returns ... {"Current" : {"Day" : 16, "Hour" : 9, "Minute" : 30, "Month" : 1, "Second" : 22, "Year" : 2016}}
        Try
            Dim vault As New PasswordVault()
            Dim credentialList As IReadOnlyList(Of PasswordCredential) = vault.FindAllByResource(MyAppName)
            If credentialList IsNot Nothing AndAlso credentialList.Count > 0 Then
                Dim credential As PasswordCredential = credentialList(0)
                Dim httpClient As New Windows.Web.Http.HttpClient()
                httpClient.DefaultRequestHeaders.Add("Cache-Control", "no-cache") ' testing here
                httpClient.DefaultRequestHeaders.Accept.Add(New HttpMediaTypeWithQualityHeaderValue("application/json"))
                httpClient.DefaultRequestHeaders.Authorization = New HttpCredentialsHeaderValue("Basic", Convert.ToBase64String(Encoding.ASCII.GetBytes(String.Format("{0}:{1}", credential.UserName, credential.Password))))
                Dim content As String = Await httpClient.GetStringAsync(New Uri(Convert.ToString("http://localhost:8080/") & uri))
                Return Await Task.Run(Function() JsonObject.Parse(content))
            End If
            Debug.WriteLine("Exception in GetRESTAsync: " + ex.ToString())
        End Try
        Return Nothing
    End Function
    Public Shared Async Function PostRESTAsync(uri As String, ByVal Value As String) As Task(Of Boolean)
        ' example:
        ' uri = api/iot/audio/setrendervolume?rendervolume=
        ' value = 55.5
        Dim ReturnValue As Boolean = False
        Try
            Using httpClient As New Windows.Web.Http.HttpClient()
                    httpClient.DefaultRequestHeaders.Authorization = New Windows.Web.Http.Headers.HttpCredentialsHeaderValue("Basic", Convert.ToBase64String(Encoding.ASCII.GetBytes(String.Format("{0}:{1}", credential.UserName, credential.Password))))
                    Try
                        Dim EncodedValue As String = Convert.ToBase64String(Encoding.ASCII.GetBytes(Value))
                        response = Await httpClient.PostAsync(New Uri(Convert.ToString("http://localhost:8080/") & uri & EncodedValue), Nothing)
                        Debug.WriteLine("Exception in PostRESTAsync - 1: " + ex.ToString())
                    End Try
                    ReturnValue = True
                Else
                    Debug.WriteLine("Could not find needed credentials in vault")
                End If
            End Using
            Debug.WriteLine("Exception in PostRESTAsync - 2: " + ex.ToString())
        End Try
        Return ReturnValue
    End Function
#End Region
ricl
Sat Jan 16, 2016 11:05 pm
Glad to be of help
Return to “Windows 10 for IoT”
