Hankus
Preview release W10 IOT?
Sun Feb 21, 2016 11:02 pm
I'm guessing the preview release you talk about is one available to developers only. Any idea how long before the general public might be able to benefit from something that sounds like the fix we're waiting for?
Re: Preview release W10 IOT?
Mon Feb 22, 2016 3:50 am
Hankus wrote:I'm guessing the preview release you talk about is one available to developers only. Any idea how long before the general public might be able to benefit from something that sounds like the fix we're waiting for?
It is easy to sign up as a Developer, I used my Microsoft Live Account details:
http://ms-iot.github.io/content/en-US/Downloads.htm
http://ms-iot.github.io/content/en-US/w ... review.htm
dobova86
Re: Display works on Raspbian Jessie, but not on W10 IOT?
Mon Feb 22, 2016 9:46 am
Is there anyone using last 14262 preview build with visual studio 2015 ?
I'm not able to install and develop with LightningProvider .. VS doesn't see the Microsoft.Iot namespace although all assemblies required are referenced (Nuget) . ... I'm missing something ?
SwampieUK
Mon Feb 22, 2016 11:02 am
craigdudley wrote:Can confirm touch does indeed work on latest preview release.
Trying to figure out how to make it work rotated now though..
Edit the config.txt on the SD card and add
display_rotate = 2
Full details are here: https://www.raspberrypi.org/documentati ... fig-txt.md
Note however, that this (for Windows IoT) only rotates the screen. It doesn't appear to rotate the touch functionality. So on the default IoT boot screen you have to tap bottom left to access the Power button, despite the screen showing it in the top right. :lol:
Two steps forward (working screen, working touchscreen) and one step back (non-rotating touch screen). Great though that MS are fixing these things though. :D
Update:
As scotty101 pointed out, the actual setting (which correctly rotates touch input) is:
lcd_rotate = 2
scotty101
Mon Feb 22, 2016 1:09 pm
Actually I think the correct command is
lcd_rotate = 2
This deals with the touchscreen too.
Source: http://learn.pimoroni.com/tutorial/pi-l ... screen-lcd
SwampieUK
Mon Feb 22, 2016 2:40 pm
Ahh, yes - you're right, that fixed it. Thanks.
stonelance
Mon Feb 22, 2016 6:49 pm
lcd_rotate=2 in the config.txt will rotate 180
craigdudley
Tue Feb 23, 2016 10:57 am
lcd_rotate=1 or lcd_rotate=3 don't seem to work though, so we're stuck in landscape for now.
Still, it's progress.
