velersoftware
Bug at startup
Sun Nov 29, 2015 6:57 pm
Hi everybody,
I have a problem with my Raspberry Pi 2 and Windows 10 Iot Core.
Usually when I start my rasp, there is no problem. But since this morning, the green LED blink, and then nothing. Nothing appear on screen. But I can connect to Windows 10 with PowerShell and my local internet connection.
Something strange : if I do a "shutdown /r /t 0" with PowerShell, the raspberry pi restart, and this time I have finally something on screen, and everything looks normal.
I have a power supply 5V - 2A. The problem appear with or without anything on USB ports and GPIO. The problem appear also with the build 10240 and 10556. I also tried with two different SD car.
The problem doesn't appear with a Raspbian distribution.
Finally : this morning, at a moment, the green LED was blinking 7 times, and then 1 second of pause, and the 7 times again...etc. From the documentation of the raspberry, it's "kernal.img not found". Strange, as I didn't get that a second time.
Any idea?
Thank you in advance,
Regards,
Etienne
q3maniac
Re: Bug at startup
Tue Jan 05, 2016 9:26 pm
I have the same (or similar) problem. Everything was working when suddenly the Raspberry Pi 2 (with Windows 10 iot) was starting to fail.
Problem: The Pi is booting up and I can detect that my WiFi-dongle (doesn't matter if I unplug this) is starting to work when suddenly it shutdowns and the green LED is blinking 7 times, and then 1 second of pause, and the 7 times again...etc.
I've reformat the SD-card and reinstalled the OS but the same problem occurs.
I'm also using a 5V - 2A power supply.
ricl
Re: Bug at startup
Tue Jan 05, 2016 10:40 pm
As the Linux guys would say, check your power supplies. Marketing is not engineering.
ricl : F/gamma = ma : Law ii(a) : https://climatedatablog.wordpress.com/2016/01/02/an-energy-challenge-2016/ #AnEnergyChallenge2016
q3maniac
Re: Bug at startup
Sat Jan 16, 2016 11:02 am
I'm back with some information.
Bought a new power supply from a Swedish supplier (http://www.r-pi.se/) without any progress.
I then changed the SD-card with a new one and everything seems to be working again. It seems my old was corrupt (even tho I could explore the files in it without any faults. I even ran chkdsk on it without any errors. This gave me the false impression that the card was working).
Hope this helps anyone else :).
ricl
Re: Bug at startup
Sat Jan 16, 2016 11:32 am
Power should be the first thing you check on the Pi if things go wrong. Just like the Linux guys do.
q3maniac
Re: Bug at startup
Mon Jan 18, 2016 7:07 pm
Apparently I'm doing something wrong with my Pi because now I've the same problem with my new SD-card! :(.
All I did was using the 'Windows Device Portal' to change the startup app and then pressed 'Restart'. Now I've the 7 green led blink at startup again.
Can somebody please explain to me what the right procedure is for deploying new code, when working with a live device?.
ricl
Re: Bug at startup
Tue Jan 19, 2016 2:14 am
Can you select the default app as startup and does that work?
q3maniac
Re: Bug at startup
Tue Jan 19, 2016 8:30 am
I could before but now the Pi doesn't even startup correctly.
It gets stuck with green led flashes 7 times and is inaccessible :(.
EDIT: I have now reformatted the card again with SDFormatter (https://www.sdcard.org/downloads/formatter_4/) and I got it to work again!. I did try the "Windows Format" feature without any progress and since chkdsk did not find any bad clusters/sectors I assume that my SD-card is good.. I don't know anymore :o
Return to “Windows 10 for IoT”
