nandannaveen
Power shell error for setting up Local PC
Mon Sep 14, 2015 3:13 pm
How to correct this error in power shell, im typing ip address of my local pc. still its not working.
PS C:\WINDOWS\system32> Set-Item WSMan:\localhost\Client\TrustedHosts -Value <192.168.0.101>
At line:1 char:54
+ Set-Item WSMan:\localhost\Client\TrustedHosts -Value <192.168.0.101>
The '<' operator is reserved for future use.
+ CategoryInfo : ParserError: (:) [], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : RedirectionNotSupported
haroldpulcher
Re: Power shell error for setting up Local PC
Mon Sep 14, 2015 5:55 pm
the '<' and '>' are indications that you need to put a value here and what it should be.
There are not part of the syntax of the command. Remove them and you should be fine.
Return to “Windows 10 for IoT”
