Engine44
Multiple Operating Systems
Tue Sep 08, 2015 6:41 pm
Can you load more than one operating system on a Pi2? For example, Raspian and Windows IoT. If you can, how do you select the one you want to run? Thanks,
UndergroundFun
Re: Multiple Operating Systems
Tue Sep 08, 2015 7:37 pm
Put a different micro SD card in it and start it back up.
r3d4
Tue Sep 08, 2015 8:49 pm
Engine44 wrote:Can you load more than one operating system on a Pi2? For example, Raspian and Windows IoT.
Unfortunately no.
RobHenry
Tue Sep 08, 2015 9:25 pm
Engine44 wrote:Can you load more than one operating system on a Pi2? For example, Raspian and Windows IoT. If you can, how do you select the one you want to run? Thanks,
Yes. A tool called berryboot does this. Don't know if it supports windows iot though. I believe noobs also let's you install two oses and choose between them but I've never used it.
r3d4
Wed Sep 09, 2015 2:29 am
RobHenry wrote: Don't know if it supports windows iot though.
Windows would need to be able to run on a SquashFS format system image AFAIK that will not be easy if it is even posible at all.
r3d4 wrote: Unfortunately no.
Revised to Not realy.
