Valkyrie-MT
Real Time Clock?
Tue Aug 18, 2015 2:40 am
Is there a Real Time Clock available on the Raspberry pi 2? If so, does Windows IoT support it ?
Thanks,
Valkyrie-MT
Re: Real Time Clock?
Tue Aug 18, 2015 6:23 am
No. There is no hardware RTC on the Pi. The time is lost when it is switched off.
ame
Tue Aug 18, 2015 6:45 am
Valkyrie-MT wrote:Is there a Real Time Clock available on the Raspberry pi 2? If so, does Windows IoT support it ?
Thanks,
Valkyrie-MT
As mentioned, there is no real-time clock. It is an OS function. Under Linux (Raspbian), the clock is set by ntp if the Pi is connected to a network. If there is no network then the clock will start counting from the beginning of the epoch (00:00, Thursday, 1 January 1970).
If you know you will never have a network connection then you can add a hardware RTC, such as this:
http://www.dx.com/p/ds3231-raspberry-pi ... ack-277258
Or you could hook up a GPS (USB or serial) and read the current time (and set the clock) from that.
Under winiot you'd have to ask MS how it works.
UndergroundFun
Tue Aug 18, 2015 5:19 pm
I've been working on time synchronization. I can get it to sync to our domain controller, but only when I run the resync manually from PowerShell when connected to the Pi. (w32tm /resync /force)
Ideally I'd be able to just run the same command from application code when it starts up. But I haven't been able to get that to work yet.
bgreer5050
Mon Dec 28, 2015 1:50 pm
I have addressed this issue by creating a task that runs on boot-up and every 15 minutes.
Create a file "SyncTime.ps1" on the Pi containing the PowerShell script to run "w32tm /resync /force".
Then run this script to create a scheduled task that runs it on start up.
schtasks /Create /SC ONSTART /TN TimeSync /TR c:\SyncTime.ps1
That will force it to sync the time when it starts up. It seems this registry key below also needs to be set to your NTP server that it's going to sync to. Mine is set to our domain controller and it's working fine.
set-itemproperty -Path HKLM:\SYSTEM\CurrentControlSet\Services\W32Time\Parameters -Name NtpServer -Value 127.0.0.1,0x9
You will have to change 127.0.0.1 to an IP that has a time service.
Source:
https://social.msdn.microsoft.com/Forum ... WindowsIoT
ricl
Mon Dec 28, 2015 3:52 pm
Please note that, like Linux, Windows 10 Core IoT also uses network time if it is available, straight out of the box. You should only need to switch to a local time server if, for some reason, the Pi cannot 'see' the outside world on boot.
ricl : F/gamma = ma : Law ii(a) : https://climatedatablog.wordpress.com/2016/01/02/an-energy-challenge-2016/ #AnEnergyChallenge2016
