vikramadhav
Constant Polling application for Event Hub as Receiver
Fri Aug 14, 2015 9:24 am
Folks ,
i need your guidance , first thought for this thinking building a background job but have layman experience in App World, i trying to build a windows app which will constant poll from event hub as Receiver. As thanks to Microsoft there is no support for Service Bus SDK. i am using SBLite as of now
How can i constantly poll message from event hub.
haroldpulcher
Re: Constant Polling application for Event Hub as Receiver
Fri Aug 14, 2015 2:54 pm
Go here:
https://azure.microsoft.com/en-us/docum ... etstarted/
This demo does what you are asking. It implements IEventProcessor, which after fired up will continuously poll for the new info from the event hub.
I did this last night. In the same solution I have both the reader and the writer. Fired up the writer, then started sending data. Fired up the reader and data just started showing up. As a test fired up a second reader, and it was getting data from the same feed. Sorta neat.
vikramadhav
Mon Aug 17, 2015 5:12 am
Thanks for your reply,
but currently there is no support for Azure.ServiceBus namespace in IoT Core. the only workaround is right now is polling via REST with a worker thread. but that's not feasible as there has to be a custom implementation retry mechanism for receive method.
haroldpulcher
Mon Aug 17, 2015 11:44 am
Ran into the same problem over the weekend while working up a talk on this very subject.
There are a couple of guys out there that have written send/recieve eventhub, but for the most part they are just doing a constant poll to get results.
There has to be a better way.
Will let you know if I find/code one.
