svigo
Raspi2 Win 10 IOT C# + MySql
Fri Aug 14, 2015 8:46 am
Hello to anyone,
Is it possible to run a C# project that connects to MySql DB with Raspi2 + Win10 IOT.
Which driver for MySql can connect should I use, since it is an ARM CPU.
Thanks for help
Svigo
Re: Raspi2 Win 10 IOT C# + MySql
Fri Aug 14, 2015 12:21 pm
The only possible way to connect would be with ODBC. I can't find any documentation on whether ODBC is supported in the Win10 IoT SDK. So you'll need to ask Microsoft for that.
This is a doctor free zone.
GerritV
Fri Aug 14, 2015 12:41 pm
There are a few choices, but ODBC seems your best option. https://dev.mysql.com/doc/connector-odb ... ation.html has information on building the connector from source.
UndergroundFun
Fri Aug 14, 2015 1:16 pm
It might be simpler to just create a WebAPI service, or some intermediate layer to handle that rather than trying to connect directly.
Or depending on what you're doing with it, to provide a client that hits a web application.
dangfrick
Sat Aug 15, 2015 1:14 am
I'm not sure what your requirements are, but if you're open to it you could just use SQLite. There's a decent guide here:
http://blog.chrisbriggsy.com/Using-SQLI ... r-Preview/
Yacko1975
Sat Aug 15, 2015 11:55 pm
I did this using the MySQL Connector for .Net located at https://dev.mysql.com/downloads/connector/net/
I downloaded the .Net & Mono Version and referenced the RT version in my Universal Windows C# application. I have MariaDB running on my Synology Diskstation and have it saving Tempatures every 15 minutes using the below function. This library does not support SSL so I had to disable it in my connection string which I have also included below.
ConnectionString
private const string csMySQL = "Server=192.168.1.150;Database=IoTApps;Uid=IoTApplication;Pwd=xxxx;SslMode=None;";
Function to save to Mysql (MariaDB in my case)
    public void InsertTemp(int LocationUID, double TempatureC)
      using (MySqlConnection dbConn = new MySqlConnection(csMySQL))
        using (MySqlCommand dbCmd = new MySqlCommand("App_Tempature_Insert", dbConn))
          dbCmd.CommandType = CommandType.StoredProcedure;
          dbCmd.Parameters.Add("LocationUID", MySqlDbType.Int32).Value = LocationUID;
          dbCmd.Parameters.Add("TempatureC", MySqlDbType.Double).Value = TempatureC;
          dbConn.Open();
          dbCmd.ExecuteNonQuery();
svigo
Mon Aug 17, 2015 6:58 am
Thanks for answer, I will try and give feedback.
Best regards,
Švigo
ppumkin
Tue Nov 03, 2015 11:32 am
Did this solution work?
ricl
Tue Nov 03, 2015 12:50 pm
There is also
47. Does Windows 10 Core IoT support SQL
A Developer's Guide to Windows 10: (10) SQLite Local Database
https://channel9.msdn.com/Series/A-Deve ... dows-10/10
Andy Wigley's Blog about it
http://andywigleyblog.azurewebsites.net/?p=721
and on GitHub
https://github.com/Windows-XAML/201505- ... SQLiteDemo
ricl : F/gamma = ma : Law ii(a) : https://climatedatablog.wordpress.com/2016/01/02/an-energy-challenge-2016/ #AnEnergyChallenge2016
mf1040
Tue Nov 24, 2015 7:48 pm
Raspberry Pi 2- remote connection, recording on mySQL.db via the Internet
My example now works. Raspberry's IP address should be open to MySQL Server
Thanks for help
Mihael and Svigo
// Copyright (c) Microsoft. All rights reserved.
using System;
using Windows.Devices.Gpio;
using TouchPanels.Devices;
//using System.Collections.Generic;
//using System.IO;
//using System.Linq;
//using System.Runtime.InteropServices.WindowsRuntime;
//using Windows.Foundation;
//using Windows.Foundation.Collections;
using Windows.UI.Xaml;
using Windows.UI.Xaml.Controls;
//using Windows.UI.Xaml.Controls.Primitives;
//using Windows.UI.Xaml.Data;
//using Windows.UI.Xaml.Input;
//using Windows.UI.Xaml.Media;
//using Windows.UI.Xaml.Navigation;
using MySql.Data.MySqlClient;
//using System.Data;
//using System.Data.Common;
//using System.Diagnostics;
using System.Threading;
using Windows.Devices.I2c;
using System.Linq;
using System.Threading.Tasks;
using Windows.UI.Xaml.Automation.Peers;
using Windows.UI.Xaml.Automation.Provider;
namespace MySql_Connect
    public sealed partial class MainPage : Page
        //server=212.44.99.2;user id=tomassho_mps;database=tomassho_mps;persistsecurityinfo=True
        private const string csMySQL = "host=xxx.44.99.xxx;" +
                                         "database=ts-servis_IoT;" +
                                         "user id=ts-servis_IoT;" +
                                         "password=xxxxjz00;" +
                                         "CharSet=utf8mb4;" +
                                         "persist security info=True;";
        public DispatcherTimer timer;
        //private Timer periodicTimer;
        int x = 25;
        double y = 23.5;
        int z = 1;
        long count = 0;
        long count2 = 0;
        public int instruc = 0;
        //int q = 0;
        private const int LED_PIN = 5;
        private GpioPin pin;
        private GpioPinValue pinValue;
        private SolidColorBrush redBrush = new SolidColorBrush(Windows.UI.Colors.Red);
        private SolidColorBrush grayBrush = new SolidColorBrush(Windows.UI.Colors.LightGray);
        const string CalibrationFilename = "TSC2046";
        private Tsc2046 tsc2046;
        private TouchPanels.TouchProcessor processor;
        private Point lastPosition = new Point(double.NaN, double.NaN);
        MySqlCommand mcd;
        public MainPage()
            this.InitializeComponent();
    // do
    //} while (true);
    private void InitGPIO()
            var gpio = GpioController.GetDefault();
            // Show an error if there is no GPIO controller
            if (gpio == null)
                pin = null;
                GpioStatus.Text = "There is no GPIO controller on this device.";
                return;
            pin = gpio.OpenPin(LED_PIN);
            pinValue = GpioPinValue.High;
            pin.Write(pinValue);
            pin.SetDriveMode(GpioPinDriveMode.Output);
            GpioStatus.Text = "GPIO pin initialized correctly.";
        //  private void TimerCallback(object state)
        //     z = 1;
        public void Timer_Tick1(object sender, object e)
            if (pinValue == GpioPinValue.High)
                z = 1;
                pinValue = GpioPinValue.Low;
                //LED.Fill = redBrush;
            else
                // LED.Fill = grayBrush;
            if (z == 1)
                //timer.Start();
                x = x + 1;
                y = y + 0.42;
                InsertTemp(x, y);
                z = 0;
                TimerStatus.Text = "Writing to MySQL DB!!! ";
            else
                TimerStatus.Text = "Waiting 5000ms!!! ";
                HelloMessage.Text = "Instruc.nr- " + count2 + ": " + instruc / 5 + " Instructs/s";
                instruc = 0;
            if (x > 100)
                x = 10;
            if (y > 100)
                y = 10;
            //throw new NotImplementedException();
            // switch (z)
            //    case 0:
            //        break;
            //    case 1:
            //       break;
            //   default:
            //       break;
        // private void Timer_Tick(object sender, object e)
        //      z = 1;
                dbConn.Open();
                        string q = "INSERT INTO App_Tempature_Insert(LocationUID, TempatureC)" +
                                  "VALUES('" + LocationUID + "', '" + TempatureC + "')";
                        ExecuteQuery(q);
        public void ExecuteQuery(string q)
            try
                    dbConn.Open();
                    mcd = new MySqlCommand(q, dbConn);
                    if (mcd.ExecuteNonQuery() == 1)
                        HelloMessage.Text = "Query Executed";
                        count2 = count2 + 1;
                        instruc = instruc + 11;
                        for (count = 1; count <= 60000000; count++)
                            instruc = instruc + 2;
                            // if (pin != null)
                            //     break; // TODO: might not be correct. Was : Exit For
                            // HelloMessage.Text = "Pin: " + pin;
                            //if (formatedTime != 5)
                    else
                        HelloMessage.Text = "Query Not Executed";
            catch (Exception ex)
                HelloMessage.Text = (ex.Message);
            finally
                    dbConn.Close();
        private void ClickMe_Click(object sender, RoutedEventArgs e)
            HelloMessage.Text = "Hello, Windows 10 IoT Core!";
        private void GpioStatus_SelectionChanged(object sender, RoutedEventArgs e)
