AndrosovIgor
Graphic problems
Thu Aug 06, 2015 6:32 pm
Hi there!
I have problem with WIn IoT.
I just flash it to SD card.
this is my config file (standart for windows IoT):
gpu_mem=32                  # set ARM to 480Mb DRAM, VC to 32Mb DRAM
framebuffer_ignore_alpha=1  # Ignore the alpha channel for Windows.
framebuffer_swap=1          # Set the frame buffer to be Windows BGR compatible.
disable_overscan=1          # Disable overscan
init_uart_clock=16000000    # Set UART clock to 16Mhz
hdmi_group=2                # Use VESA Display Mode Timing over CEA
But, in dispalay I see this:
This is base screen of Windows IoT
Can some one help me?
Re: Graphic problems
Thu Aug 06, 2015 8:33 pm
It's very difficult to help when your link to your screen shot failed dismally.
Put the picture on http://imgur.com, post the IMGUR "direct link" on here in [IMG] tags.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
Thu Aug 06, 2015 9:18 pm
Your screen is supposed to look like this:
I know, bad joke.
kusti8
Thu Aug 06, 2015 11:45 pm
Heater wrote:Your screen is supposed to look like this:
I know, bad joke.
That reminds me of my signature. ;)
There are 10 types of people: those who understand binary and those who don't.
AndrosovIgor
Fri Aug 07, 2015 4:11 am
Hi again!
This is an image of screen
Fri Aug 07, 2015 9:38 am
Shut it down.
Pull the card and insert it in your laptop.
A drive EFIESP (F:) should appear note: the drive letter may be different.
Edit F:\config.txt with notepad. It should look something like this:
Change it to this for the last two lines
hdmi_group=2                # Use VESA Display Mode Timing over DMT
hdmi_mode=16
save the file, pop it back in your RPi and reboot. Mode 16 gives you 800x600 which should work on any monitor or TV.
AndrosovIgor
Fri Aug 07, 2015 5:08 pm
Thanks, it solve this issue :)
Return to “Windows 10 for IoT”
