equivalent to DataSet and SqlConnection ?
Posted: Wed Jul 15, 2015 12:41 pm
by beta-tester
i want to port my existing C# .NET 4.0 Desktop (Any CPU) software to Windows IoT (ARM).
in that software i make use of System.Data.DataSet/System.Data.DataTable/... and access to Microsoft SQL Server (tables and stored procedures) via System.Data.SqlClient.SqlConnection...
but the references i used in the desktop environment does not exist in the univeral environment...
so DataSet, DataTable and SqlConnection are not usable on Windows IoT...
does somebody know how to adapt the functionality or which references i have to use for DataSet / DataTable / SqlConnection?
for DataSet / DataTable i can maybe use other stuff... but to access to a MS SQL Database / Table / StoredProcedure i don't know how to adapt...
Re: equivalent to DataSet and SqlConnection ?
Posted: Thu Jul 16, 2015 12:51 pm
by Berndt73
Create a WCF service and pass JSON around.
Posted: Thu Jul 16, 2015 7:57 pm
by UndergroundFun
Rewrite it as a web application. Then just display it through a browser app.
That seems pretty ridiculous that System.Data would not be available. Unless it's just not ready yet.
Posted: Thu Jul 16, 2015 8:31 pm
by MieliSpoor
Have you tried using Linq with EntityFramework 7? If that doesn't work, just create either a WCF Rest service of MVC WebAPI and get all you data that way.
If the device won't have network access in such a way, you can also try SQL-Lite for local storage.
Posted: Fri Jul 17, 2015 7:37 pm
by beta-tester
thank you guys for your answers...
i can not create a WCF service, because i don't have permission to do so on the server, it is not hosted by me.
i only have access to the server database by connectionstring with my user and password authentification.
creating a local SQLite database makes no sense to me...
then i have to communicate to the MS SQL database anyhow, to sync the data. for that i again have the same problem, how to do the transactions between the both databases with only use of connectionstring SqlClients SqlConnections.
or does SQLite have the functionality to mirror/replicate/sync between SQLite and MS SQL?
Posted: Sat Aug 08, 2015 12:33 am
by scvn
Bumping this since I'm in the same situation as the creator of the post.
Posted: Sun Aug 09, 2015 4:58 pm
by beta-tester
i thinking about to implement the mono adaption of SqlConnection
https://github.com/mono/mono/tree/maste ... .SqlClient
unfortunately the source is currently not done available on microsoft side yet:
https://github.com/dotnet/corefx-progre ... /README.md
but maybe it is better to "yield" and follow the mainstream philosophy of the limited universal possibilities and use web services...
but that will be a very hard thing to persuade the SQL server admin to add those support and give the manpower to implement...
hmm who knows, :?
(i remember, where is was in a similar situation by implementing a Silverlight App and trying to persuade the server admin to do web services without success - the project miserably died because of unwanted supporting the project on server side)
