Juliemac
Power button on IoT
Sat Jun 27, 2015 12:21 pm
I booted the system read what I saw, then tried to power down. But the power button on the top right is non functional as if it is disabled. (grayed out)
What is the correct method to shut down the OS?
Re: Power button on IoT
Sat Jun 27, 2015 4:21 pm
Juliemac wrote:I booted the system read what I saw, then tried to power down. But the power button on the top right is non functional as if it is disabled. (grayed out)
PowerShell - Shutdown/restart device:
To shut down your device, type shutdown /s /t 0. To restart the device, use the /r switch instead with the command shutdown /r /t 0.
http://ms-iot.github.io/content/en-US/w ... eUtils.htm
Retired disgracefully.....
......to a more gentile life !
Juliemac
Sun Jun 28, 2015 4:06 pm
So that "button" on the top right is not a power button?
Thanks!
jtanner_msft
Mon Jun 29, 2015 11:59 pm
It is a powerbutton, but it is currently disabled.
In addition to using the shutdown command, you can also control the device power state using the 'WebB' interface.
Note that it has now changed so it defaults to port 8080, so to access it use:
http://<ip address>:8080
I hope this helps.
Jonathan Tanner | Microsoft | Windows 10 IoT Core Insider Preview Support | This posting is provided 'as is' with no warranties and confers no rights.
