SoftReaper
Windows 8 RT and Windows IoT BootLoader
Fri Jun 12, 2015 8:46 pm
Hi everybody,
I recently bought a raspberry 2 and tried Windows IoT (formerly C# developper I wasn't really disapointed by it) but I'm a bit sad to see that, unlike many websites and IT specialists says, IoT is not a fully functionnal OS (not for customer side like a linux distro could be with desktop manager and file explorer) so i'm trying to install Windows 8 RT from the recovery Image of my Surface RT (first generation)
it could run on raspberry pi 2 only (newer arm arch compared to raspberry 1, more ram, directx compatible GPU and more):
http://www.xda-developers.com/htc-hd2-r ... indows-rt/
this one work only with efi enabled custom bootloader (not released by dark forces team)
http://forum.xda-developers.com/showpos ... ostcount=4
so vhd native boot work on windows 8 RT with arm BCD bootloader
so the question is: how did the efi boot process work for Windows IoT (I suppose that Raspberry firmware doesn't support UEFI natively unlike linaro's kernels for beagleboards) for booting my Windows RT Native VHD
the raspberry is shipped and it'll be here next week. And the last thing I need to know is: do I just need to add a line to the Boot Catalog with the VHD or manipulate every files contained in the iot SD image?
i don't want to publish the result online but I thought that it could be nice to provide windows environement next to linux to cover all usages so the knowledge will be the only target.
thanks by advance and sorry for my poor english
Best Regards
SoftReaper
Re: Windows 8 RT and Windows IoT BootLoader
Sat Jun 13, 2015 7:35 am
fyi the ARM Chip Windows RT was coded for is a different variant to what is used in the RPi ;)
adieu
My other Computer is an Asus CS10 ChromeBit
SoftReaper
Sat Jun 13, 2015 8:51 am
i'll try when I recieve the raspberry, but as my link show it, it worked on old unsupported arm v7 without much work than bootloader rework, so i'm optimistic
i'll post a logwork on this thread
Best regards
mimi123
Sun Jun 14, 2015 6:32 am
SoftReaper wrote:Hi everybody,
Best Regards
SoftReaper
You have 2 choices:
-code an HAL extension(nthalext.h in the 8.1 WDK) and enable testsigning
-be happy with Windows 10 Mobile(that can also be used)
SoftReaper
Sun Jun 14, 2015 4:12 pm
oh, i'm happy with 10 IoT, but beside it and linux, i'm just curious to see if it could work with minimmum operation on the system.
i'll look at HAL exts like you said, thanks for the tip
edit:
as i just read about HAL extentions, it's mainly requiered for cortex A9 (tegra 2 and 3) since they didn't embeds system timer unlike cortex A15 and A7 so, it'll work out of box with RT 8.1 but not sure for 8
mimi123
Sun Jun 14, 2015 6:32 pm
SoftReaper wrote:oh, i'm happy with 10 IoT, but beside it and linux, i'm just curious to see if it could work with minimmum operation on the system.
edit:
For 8.1 and builds older than the 10030 range, a HALext is needed for the Pi2's interrupt controller[it isn't a GIC]
SoftReaper
Sun Jun 14, 2015 6:55 pm
ok, i'll go deeper and read BCM2836 datasheet (if i can get it anywhere, hard to find) thanks for the information
edit: the way to build hal extentions is reserved to windows phone oems
https://dev.windowsphone.com/en-us/OEM/ ... EM_drivers
i've just compared windows RT and IoT mainOS partition and saw those things:
there is 7 Hal Exts in 10 vs 2 in RT
2 are in common: Tegra 2 and PL310 Cache Controller
in the 5 remainings in windows 10 there is:
3 dedicated to snapdragon S4
1 for PL080 and SP804
The 804 works the same way as the one included in BCM2835/6 but with 32/16 bits register widths in places of 64/32
The 080 is DMA related so not the kind of things that i'm looking for at this time (but it looks to be the same DMA controller as the one present in the BCM2835
tryed to boot windows IoT on qemu but it's a pain to make it work on windows so i'll retry under opensuse later
SoftReaper
Thu Jun 18, 2015 6:54 pm
as promised i get back to you,
as mimi123said it doesn't work, (error 0x000005C which refers to an HAL error) without the ability to get informations to how build HAL extensions i can't go further. So it is feasable on another SBC (allwinner based as they are strictly based on arm specs) but not applicable to raspberry without modifications
thanks you for all your answers
mimi123
Fri Jun 19, 2015 10:41 am
SoftReaper wrote:as promised i get back to you,
You can build HAL extensions yourself.
See the nthalext.h in the WDK and don't forget to build it as a DLL.
SoftReaper
Fri Jun 19, 2015 7:20 pm
i'm getting the WDK tkanks for your help, i'm sorry if i look as a spotless mind, but i'm new into system oriented developpment
sortaloc
Wed Sep 02, 2015 11:52 am
I have tried to put the Windows Surface's recovery files from its install.wim into the MainOS partition. I can see it can enter the recovery screen but suddenly it reboot [attachment=1]Screenshot_65.png[/attachment]. If I'm not mistaken, I replace the boot files with files from the recovery.
[attachment=0]11938930_10206314942924958_1008670586_n.jpg[/attachment] The second picture showed when I put the winre.wim or install.wim files into MainOS partition. Sorry, low quality picture.
2nd Picture
1st Picture
pavansky
Sun Sep 06, 2015 7:39 pm
Hi there. Found your post while googling, Any progress on booting into win 8 rt.. I have got a touchscreen monitor..wanted to put win 8/10 with touch gui on my rpi 2.. really appreciate what you are trying to do..
sortaloc
Wed Sep 09, 2015 7:21 am
pavansky wrote:Hi there. Found your post while googling, Any progress on booting into win 8 rt.. I have got a touchscreen monitor..wanted to put win 8/10 with touch gui on my rpi 2.. really appreciate what you are trying to do..
I'm still in trying to find the Windows IoT boot schemes. I think if we could find its scheme. We can put the Windows RT bootloader into our rpi2 with Windows IoT partition. Do you know the Data Partition use for on Windows IoT? There're 3 mounted volumes on MainOS partition.
mimi123
Sun Sep 20, 2015 7:33 am
Try Windows 10 Mobile, it nearly works (crash in sihost now) with creating an FFU
p1u3sch1
Thu Sep 24, 2015 5:48 pm
How did you create the Windows 10 Mobile FFU?
dirtbikerxz
Sat Oct 24, 2015 2:18 am
Hey guys, sorry for the bump, but has any progress been made on loading rt on the pi?. I'm working on a project for school right now, and its a nightmare working with raspbian, windows would make it much easier. I noticed its been a month since the last reply, please let us know, if any progress has been made, and by some miracle rt is working. Thanks in advance.
Sat Oct 24, 2015 1:25 pm
dirtbikerxz wrote:Hey guys, sorry for the bump, but has any progress been made on loading rt on the pi?. I'm working on a project for school right now, and its a nightmare working with raspbian, windows would make it much easier. I noticed its been a month since the last reply, please let us know, if any progress has been made, and by some miracle rt is working. Thanks in advance.
Cannot help on the Windows thing, but why is Raspbian a problem? I do dev work on LInux all the time, it's not usually a problem.
ame
Sat Oct 24, 2015 1:28 pm
What are some of the problems you have been having? Perhaps they can be easily solved with some help?
Sat Oct 24, 2015 1:47 pm
Windows RT ARM OS is not the same as Windows x86 Desktop so you could not install regular desktop software :shock:
https://en.wikipedia.org/wiki/Windows_RT
adieu
Sat Oct 24, 2015 1:55 pm
I suspect since there's only about three people in the world interested in getting WinRT running that it's never going to happen. The folks who own the code (Microsoft) appear to have no desire to do it and since it's not open source you're going to have an impossible task if you get any bugs that need fixing.
Forget it, stick with a supported main-stream OS.
dirtbikerxz
Sat Oct 24, 2015 2:04 pm
Ah okay, thanks guys. And its not really problems I'm having with raspbian, but some of the things I'm doing will take about 5 sec on windows, whereas it takes 2 min or raspbian (the whole setup process and all). So its just a bit annoying, but that's fine. Thanks again guys.
vr6cer
Sun Mar 06, 2016 11:09 pm
sortaloc wrote:I have tried to put the Windows Surface's recovery files from its install.wim into the MainOS partition. I can see it can enter the recovery screen but suddenly it reboot [attachment=1]Screenshot_65.png[/attachment]. If I'm not mistaken, I replace the boot files with files from the recovery.
Hello, how did you managed that? Could you explain it please? Thank you!
Raspberry PI 3 Model B, Xiaomi Redmi Note 2 16 GB Global ROM 7.1.3 w root, Sony Playstation 2 120GB FHDB-MOD (Sony HDD-adapter), Playstation 3 12GB+500GB HDD OFW, Asus T200TA 2GB/64GB Win 10 Pro, VW Golf MK3 VR6 '92
mimi123
Tue Mar 08, 2016 4:49 pm
It's that the Pi doesn't use a standard GIC interrupt controller, and STILL doesn't in the Pi3. I think it's the only Cortex-A7 or A53 piece of hardware having a non-standard interrupt controller.
I think that reversing the interrupt controller's HAL extension ABI, if it even exists...
(or a FrankenWindows with running the W10 kernel with 8.1 userspace)
mimi123
Tue Mar 08, 2016 5:01 pm
He did nothing. Winload stops the system, it can't set up the GIC because it doesn't exist ;) (can be seen with a kernel debugger)
