Shep
Error 1603 installing Win10 SDK
Sun May 10, 2015 12:57 pm
Anyone else having this problem? I'm trying to install the Windows 10 SDK for VS2015 so I can get developing with my Pi, but it's giving me this error any time I try to install it:
[attachment=0]Error.png[/attachment]
If I click on "Common issues and workarounds", it brings up a page that doesn't list this error. Two relevant sections in the log file:
[0FA4:0CEC][2015-05-10T08:38:10]w308: Automatic updates could not be paused due to error: 0x80040154. Continuing...
Way early on, and later this:
[26A0:06F8][2015-05-10T08:42:55]i000: MUX:  Updating secondary installer progress display name: Microsoft Visual Studio Emulator for Android
[26A0:0FA0][2015-05-10T08:43:38]i000: MUX:  ExecuteError: Package (VSSecondaryInstaller_box) failed: Error Message Id: 1603 ErrorMessage: Microsoft Visual Studio Emulator for Android : The installer failed. Fatal error during installation. Error code: 1603
[0FA4:0CEC][2015-05-10T08:44:09]e000: Error 0x80048646: Process returned error: 0x80048646
[0FA4:0CEC][2015-05-10T08:44:09]e000: Error 0x80048646: Failed to execute EXE package.
[26A0:0FA0][2015-05-10T08:44:09]e000: Error 0x80048646: Failed to configure per-machine EXE package.
[26A0:0FA0][2015-05-10T08:44:09]i000: MUX:  Installation size in bytes for package: VSSecondaryInstaller_box MaxAppDrive: 0  MaxSysDrive: 445533184  AppDrive: 0  SysDrive: 17247232
[26A0:0FA0][2015-05-10T08:44:09]i000: MUX:  ExecutePackageComplete for secondary installer
[26A0:0FA0][2015-05-10T08:44:09]i000: MUX:  Disconnecting secondary installer pipe
[26A0:0FA0][2015-05-10T08:44:09]i000: MUX:  Return Code:0x80048646 Msi Messages:Microsoft Visual Studio Emulator for Android : The installer failed. Fatal error during installation. Error code: 1603 Result Detail:0 Restart:None
[26A0:0FA0][2015-05-10T08:44:09]i000: MUX:  Set Result: Return Code=-2147187130 (0x80048646), Error Message=Microsoft Visual Studio Emulator for Android : The installer failed. Fatal error during installation. Error code: 1603, Result Detail=, Vital=False, Package Action=Install, Package Id=VSSecondaryInstaller_box
[26A0:0FA0][2015-05-10T08:44:09]i000: Setting string variable 'BundleResult' to value '0'
[26A0:0FA0][2015-05-10T08:44:09]w350: Applied non-vital package: VSSecondaryInstaller_box, encountered error: 0x80048646. Continuing...
Anyone else have this problem before, or know how to fix it? I suspect the first one is due to Windows Update (it's trying to install a driver, but a newer version is already installed, so it continuously fails), but the second I can't seem to get around for the life of me.
jonesypeter
Re: Error 1603 installing Win10 SDK
Sun May 10, 2015 1:45 pm
There is a post on the Microsoft Support site here which may help? Are you using the Windows 10 Technical preview or something different?
https://social.msdn.microsoft.com/Forum ... um=vssetup
What specification is your PC - Not sure why but it seems to need HyperV support.
Shep
Sun May 10, 2015 9:38 pm
jonesypeter wrote:Hi,
Running Windows 10 Home Technical Preview on my Asus U47A, but HyperV isn't even an option in Windows. It's enabled in the BIOS (just checked to verify also), but the option doesn't exist in the "Add or remove Windows Features" dialog, and I can't figure out why not.
Sun May 10, 2015 9:51 pm
Prior to installing VS did you fully update W10, under Updates you need to change to "Fast Ring" t get latest:
http://www.cnet.com/uk/how-to/change-to ... ew-updates
Though to be honest this is not a Raspberry Pi issue, but a Windows Issue which sholud be resolved via the appropriate MS Forum :!:
https://dev.windows.com/en-us/downloads ... tudio-2015
https://social.msdn.microsoft.com/Forum ... oolsIssues
RPi 4B 4GB (SSD Boot)..
Shep
Mon May 11, 2015 12:08 am
fruitoftheloom wrote:Prior to installing VS did you fully update W10, under Updates you need to change to "Fast Ring" t get latest:
Yes, although that post is from January and there's no difference in updates available today.
fruitoftheloom wrote:Though to be honest this is not a Raspberry Pi issue, but a Windows Issue which sholud be resolved via the appropriate MS Forum :!:
From the sticky:
this forum is for discussing the use and programming on Win10 IoT for the Raspberry Pi.
Emphasis mine. Which applies to this thread. I'm trying to program my Raspberry Pi via my laptop, both of which are on Windows 10 IoT, but am running into issues.
Mon May 11, 2015 6:00 am
The version of Windows 10 I have installed and updated is now:
Windows 10 Pro Insider Preview
Evaluation copy. Build 10074
Visual Studio was downloaded from https://dev.windows.com/en-us/downloads ... oper-tools
Microsoft Blend for Visual Studio Community 2015 RC
Version 14.0.22823.1 D14REL
Microsoft .NET Framework
Version 4.6.00057
Installed Version: Blend
jtanner_msft
Mon May 11, 2015 6:55 pm
It sounds like you've been able to get setup for development, but just in case you are still seeing an error it's possible that the SDK did not get installed correctly. For that we do have a suggested work-around:
Can you follow the steps here: http://ms-iot.github.io/content/win10/SetupPC.htm
We have had some customers report installation issues with the previous step. As a workaround, please go to the Windows Developer Tools Preview page here https://dev.windows.com/en-US/downloads ... oper-tools, scroll down to the bottom of the page to the “Other download options” section and install “Standalone Windows 10 SDK for Windows 10” and “Microsoft Windows 10 Emulator for Mobile”.
Jonathan Tanner | Microsoft | Windows 10 IoT Core Insider Preview Support | This posting is provided 'as is' with no warranties and confers no rights.
Shep
Mon May 11, 2015 11:18 pm
jtanner_msft wrote:It sounds like you've been able to get setup for development
Nope, still having issues.
jtanner_msft wrote:it's possible that the SDK did not get installed correctly. For that we do have a suggested work-around:
Stuck on bullet point #2 there.
jtanner_msft wrote:We have had some customers report installation issues with the previous step. As a workaround, please go to the Windows Developer Tools Preview page here https://dev.windows.com/en-US/downloads ... oper-tools, scroll down to the bottom of the page to the “Other download options” section and install “Standalone Windows 10 SDK for Windows 10” and “Microsoft Windows 10 Emulator for Mobile”.
Running into issues with that too. I saved the standalone SDK installer, and when I ran it, it downloaded some things to [[ C:\Users\****\Downloads\Windows Kits\10\StandaloneSDK ]]. Running the "sdksetup.exe" file, I immediately get this message:
Which, unless it installed that quickly, isn't accurate. Now what?
jtanner_msft
Tue May 12, 2015 12:00 am
Given the errors it's possible you're seeing this issue because your system doesn't support Hyper-V:
Please try running the installer for the emulator separately, you'll be able to find the location for it in the log file you just posted, there will be an entry that shows the cached location.
Shep
Tue May 12, 2015 3:47 pm
jtanner_msft wrote:Given the errors it's possible you're seeing this issue because your system doesn't support Hyper-V:
That's the thing -- it's enabled in the BIOS, but I don't see anywhere to enable it in the OS. It's not under the Windows features section like it should be, so I can't enable it and I'm not sure why.
jtanner_msft wrote:Please try running the installer for the emulator separately, you'll be able to find the location for it in the log file you just posted, there will be an entry that shows the cached location.
Looked through the log file for something obvious, but didn't see anything -- any keywords I can use to search for it?
jtanner_msft
Tue May 12, 2015 7:01 pm
Can you complete the install of everything else and just skip the emulator installation section? If that works then you should be able to start building and deploying to your Rpi2 device.
Shep
Tue May 12, 2015 10:04 pm
jtanner_msft wrote:Can you complete the install of everything else and just skip the emulator installation section? If that works then you should be able to start building and deploying to your Rpi2 device.
Hmm, so the SDK is for the emulator only? Didn't realize that. Okay then, I tried going on to the next step, which reads:
Install WindowsDeveloperProgramForIoT.msi. It can be found inside any of the Windows 10 IoT Core Insider Preview Image files (for example, Windows 10 IoT Core Insider Preview Image for Raspberry Pi 2.zip) here
But when I click the link, it takes me to this page, which looks like this:
Regardless of what choice is selected prior to clicking the Filter button. I thought the links might just be invisible in Chrome, so I tried the new Project Spartan browser, and same thing happens there too. Where can I find the WindowsDeveloperProgramForIoT.msi file if it's not on that page? Is there a mirror for it somewhere?
By the way, thank you for taking the time to help me out here! I really, really appreciate it! :D
jtanner_msft
Wed May 13, 2015 12:48 am
Hi Shep,
I’m sorry that you are having these setup / install problems.
What I was trying to say about the SDK install is that in addition to installing the headers and libs that you need to build applications, it will also be trying to install the emulators. If you have a real device to deploy to, you shouldn’t need the emulators so that would be a step you could skip as a work-around for the time being.
As to why you’re not able to find ‘WindowsDeveloperProframForIoT.msi’ it’s probably because you have not self-nominated yourself for the IoT program. Once you do and accept the EULA then you should see a list of packages that you can select from to download. Here is the self-nomination link:
https://connect.microsoft.com/windowsem ... ramID=8558
I hope this helps.
Shep
Thu May 14, 2015 12:44 am
jtanner_msft wrote:What I was trying to say about the SDK install is that in addition to installing the headers and libs that you need to build applications, it will also be trying to install the emulators. If you have a real device to deploy to, you shouldn’t need the emulators so that would be a step you could skip as a work-around for the time being.
I never cared for debugging on emulators. Generally they're slower and bulkier than the real thing (at least, from my mobile development experience anyways), so I've always opted to have a real device handy to test to.
jtanner_msft wrote:As to why you’re not able to find ‘WindowsDeveloperProframForIoT.msi’ it’s probably because you have not self-nominated yourself for the IoT program. Once you do and accept the EULA then you should see a list of packages that you can select from to download. Here is the self-nomination link:
I hope this helps.
It does! Just got through the rest of the steps without a hitch! Thanks a million! :D
jtanner_msft
Thu May 14, 2015 1:38 am
I'm glad to hear you're unblocked now. Have fun trying out Windows 10 IoT Core.
