Massi
Re: DS18B20 Temperature Sensor / 1-Wire on Windows 10
Fri Nov 13, 2015 1:03 pm
as far as i have understood, at the moment it's impossible to write "user" code that manages precise timings.
So, i.e., it's impossible to get a DHT22 sensor to work (it's impossible to precisely time interrupts)
To me, this is a massive limit for iot.
ame
Fri Nov 13, 2015 1:44 pm
trashcoder wrote:
paul777 wrote:Hi,
Did you ever find a good solution for this I'm looking at the same problem myself?
thanks
I ended up using an Arudino connected to the Pi via I2C...
Anything but Linux.
ricl
Fri Nov 13, 2015 2:34 pm
But for half the price of a DS18B20 you can get
https://www.adafruit.com/products/2635
Adafruit HDC1008 Temperature & Humidity Sensor Breakout Board (I2C)
PRODUCT ID: 2635
$7.50
IN STOCK
with a higher sampling specification.
ricl : F/gamma = ma : Law ii(a) : https://climatedatablog.wordpress.com/2016/01/02/an-energy-challenge-2016/ #AnEnergyChallenge2016
Fri Nov 13, 2015 5:28 pm
How much do you pay for your DS18B20s? :shock:
I bought ten for around that price.
ricl
Fri Nov 13, 2015 6:08 pm
You can improve significantly on those specs at a lower price (given the ease of integration of it over I2C)?
"This I2C digital humidity sensor is a fairly accurate and intelligent alternative to the much simpler Humidity and Temperature Sensor - SHT15 Breakout It has a typical accuracy of ±4% with an operating range that's optimized from 10% to 80% RH. Operation outside this range is still possible - just the accuracy might drop a bit. The temperature output has a typical accuracy of ±0.2°C from -20~85°C."
adambarath
Sat Nov 14, 2015 6:10 pm
I also gave up and now I'm using Rinsen library with https://www.abelectronics.co.uk/p/60/1-Wire-Pi-Plus
NameOfTheDragon
Mon Nov 16, 2015 2:49 am
trashcoder wrote:Has anybody looked in to getting 1-wire devices working on Windows 10 yet?
To give a slightly indirect answer, I have written a 'driver' for the Melexis MLX90614 contactless temperature sensor. The device is a thermocouple with a built-in DSP, it reports ambient temperature and the temperature of whatever you point it at. It is an I2C device. I've written code to drive the device and a sample app to show how to use it.
Code: https://bitbucket.org/tigra-astronomy/ta.uwp.devices (this is an ongoing project)
Video of the sample app: https://www.facebook.com/NameOfTheDrago ... 9141984838
You can get the devices pretty cheaply, for example: http://www.ebay.co.uk/itm/MLX90614-Cont ... SwFnFV8PPl
They are pretty awesome little devices!
selom
Thu Jan 28, 2016 7:00 pm
I was able to read the DS18B20 using the UART, all my tests show the numbers are accurate will post details later
ricl
Thu Jan 28, 2016 7:50 pm
Indeed.
I have in progress with Microsoft a OneWire UART project that essentially follows the Dallas application note and as already built for Linux.
