In the "Web management performacence" using the default APP only, you can see that using the mouse (moving the pointer quickly) only consumes me up to 60% of the CPU as well as I / O (No run any application).
The W10 IOT support 4 CPU cores?
Many lags occur to run my application.
Does anyone have any good example of config.txt present in EFIESP to recommend?
Perhaps the problem is is some wrong setting in this file.
My default is config.txt:
framebuffer_ignore_alpha = 1 # Ignore the alpha channel for Windows.
framebuffer_swap = 1 # Set the frame buffer to be Windows compatible BGR.
disable_overscan = 1 # Disable overscan
init_uart_clock = 16000000 # Set UART clock to 16Mhz
hdmi_drive = 1
hdmi_mode = 4
hdmi_group = 1
max_usb_current = 1
Thanks,
