is the DefaultApp (IoTCoreDefaultApp) supposed to be working with a mouse?
The screen looks like it ... "OFF" button, "settings" button ...
Christoph
You're right, interesting. I've just connected a USB mouse to the Pi and it indeed is working. Which leads me to the "right" question:John_ wrote:When I connect a mouse to the PI it does indeed work on the screen where it starts up with.
max_usb_current=1Apart from the fact that the default app crashed twice when I moved the wireless mouse no real successDougieLawson wrote:... edit F:\config.txt, addsave it, safely eject it, reboot the RPi.Code: Select all
max_usb_current=1
Logitech K260 and K270 sets don't work for me neither. However, I have a MS "Wheel Mouse Optical" wired mouse which works well.hyla wrote:You're right, interesting. I've just connected a USB mouse to the Pi and it indeed is working. Which leads me to the "right" question:John_ wrote:When I connect a mouse to the PI it does indeed work on the screen where it starts up with.
Why doesn't the Logitech K260 wireless desktop set work that I'm trying to use? It's connected via a powered USB hub.
Christoph
max_usb_current=1
