Page 2 of 3
Re: Install Windows 10 for IoT using Windows 7
Posted: Sat May 16, 2015 2:25 pm
by John_
ferhat wrote:Hello guys,
I read here that some guys were able to boot Windows 10 IoT with RP2.
I downloaded and installed Windows 10 ADK, where I got my dism.exe. My host machine is a Windows 7 vmware virtual machine.
I passed my SD-card reader/writer to my VM so I was able to write the image with dism.
I performed the steps described here: http://ms-iot.github.io/content/win10/SetupRPI.htm
Right after inserting the SD card into my RP2 I could see "Graphics Console started", a windows logo and a blue screen. Thats all. Nothing happens after that.
Any ideas?
Thanks,
Ferhat
How long did you wait? You need a bit of patience on first boot. In the end it will get there.
Posted: Sat May 16, 2015 2:54 pm
by ferhat
Hmm.. I waited for about 10 minutes. There was no progress.
Is there a log file which I can check?
Posted: Sun May 17, 2015 8:28 am
by John_
ferhat wrote:Hmm.. I waited for about 10 minutes. There was no progress.
Not that I know, 10 minutes should be enough. Strange because the fact that you see the windows logo means that the image is correctly written to the SD card. Do you have another SD card laying around? Might be worth on trying that. Also make sure you have a good power connector connected to the PI, I had one that was not providing enough power at the beginning and that gave some issues.
Posted: Sun May 17, 2015 7:57 pm
by ferhat
I tried it several times with no success. So I switched back to Ubuntu Mate.
I will try it again with another SD card but I think this is not necessary because Raspbian and Ubuntu Mate work fine.
I am using this power connector:
http://www.amazon.de/dp/B00GM0305Y
But I recognized something which I don't understand:
I had to repeat writing my ubuntu mate image 3 times until PI was able to boot again.
Thanks,
Ferhat
Posted: Sun May 17, 2015 8:06 pm
by disk4m3
hello when attempting to perform this action tells me unknown image file Error: 87 . i running DISM.exe , that problem is it?
thanks
Posted: Mon May 18, 2015 3:38 am
by John_
disk4m3 wrote:hello when attempting to perform this action tells me unknown image file Error: 87 . i running DISM.exe , that problem is it?
thanks
I got this error when I didn't copy all of the DLL's that were part of the folder where dism.exe came from. Are you sure you copied all other files from the folder where dism.exe came from?
Posted: Mon May 18, 2015 3:44 am
by John_
ferhat wrote: I had to repeat writing my ubuntu mate image 3 times until PI was able to boot again.
Thanks,
Ferhat
hmm, seems there is something with the SD card then perhaps. Its always a bit of trial and error with these kind of issues as it could be the SD or still the power supply. But the power supply seems ok. So if you have another SD card somewhere, I think that would be the best path to follow.
Posted: Mon May 18, 2015 5:36 pm
by ferhat
Thanks,
Ferhat
Tried another SD card now. It worked like a charm.
Testing my other SD card with "badblocks" now. Actually it is a brand new SandDisk Class 10 sd card.
Thanks,
Ferhat
Posted: Mon May 18, 2015 6:00 pm
by John_
ferhat wrote: Tried another SD card now. It worked like a charm.
Good to hear that it works!. If its a brand new sanddisk, you should probably be able to return it.
Posted: Sat May 23, 2015 2:01 pm
by AlexCornelis
I try to install Win 10 IOT on my Pi 2B, but .. on my Windows 7 Pc (Home premium) I get an error on dism.exe /Apply-Imag ...
He seems not to know the /Appy-Image .
Is there a solution/workaround ?
Posted: Sat May 23, 2015 2:20 pm
by GerritV
AlexCornelis wrote:I try to install Win 10 IOT on my Pi 2B, but .. on my Windows 7 Pc (Home premium) I get an error on dism.exe /Apply-Imag ...
Did you follow these steps exactly? If you do then you will have the correct version of dism.exe and not get this error. viewtopic.php?p=750492#p750492
If you copied the correct version of dism and still get the error, then prefix dism.exe with the full path to where you placed it.
Posted: Sat May 23, 2015 3:51 pm
by DougieLawson
AlexCornelis wrote: Is there a solution/workaround ?
The way I've done this (on my Win8.1 laptop) is to run Win10 in a Oracle VM Virtualbox. I didn't want to risk pushing my laptop on to an untested version of Windows.
https://www.virtualbox.org/
Posted: Tue Jun 02, 2015 9:21 am
by Jednorozec
Microsoft says
Windows 10 Insider Preview - must be a physical Windows machine (not a VM).
Did you have to do anything special to make it work?
Posted: Tue Jun 02, 2015 11:58 am
by DougieLawson
Only special thing was getting the very latest version of Oracle's virtualbox and giving it a 120MB chunk of my hard drive.
Posted: Sat Jun 06, 2015 6:31 pm
by funtomas
could someone post user and password for windows 10 on raspi?
its
Administrator
[email protected]
edit: installed from first post but there is error you must use Flash.ffu with big F
edit2: ssh on windows
Posted: Sat Jun 06, 2015 6:55 pm
by John_
funtomas wrote: edit: installed from first post but there is error you must use Flash.ffu with big F
thanks for the info, i thought my flash.ffu was with lower case, but I updated the first post and made a remark on lower case.
Posted: Mon Jun 08, 2015 4:23 am
by jozien1722
"dism.exe /Apply-Image /ImageFile:Flash.ffu /ApplyDrive:\\.\PhysicalDriveN /SkipPlatformCheck"
I followed the above instructions and get an error:
"Apply-Image option is unknown"
I checked c:\Windows\logs\dism and get "no providers found that support the command
(Apply-Image)"
Where did you download dism.exe that has the option "Apply-Image"?
jozien1722
Posted: Mon Jun 08, 2015 5:51 am
by John_
jozien1722 wrote:"dism.exe /Apply-Image /ImageFile:Flash.ffu /ApplyDrive:\\.\PhysicalDriveN /SkipPlatformCheck"
(Apply-Image)"
jozien1722
Did you do step 1-3 exactly like mentioned in the first post? You will get the error message "Apply-Image option is unknown" if you don't copy all the files from the folder where you got dism.exe from. So if you follow step 1-3 to the letter, it should work.
Posted: Mon Jun 08, 2015 11:13 am
by Quiggers
I'm getting the same error 87 Apply-Image is unknown.
when I run dism.exe /?
it lists the supported commands but Apply-Image is not on the list.
There are only 7 commands for the version of dism on my PC.
/Get-MountedWimInfo
/Get-WimInfo
/Commit-Wim
/Unmount-Wim
/Mount-Wim
/Remount-Wim
/Cleanup-Wim
Running windows 7 professional SP1 64Bit.
Posted: Mon Jun 08, 2015 11:18 am
by John_
Quiggers wrote:I'm getting the same error 87 Apply-Image is unknown.
/Get-MountedWimInfo
/Get-WimInfo
/Commit-Wim
/Unmount-Wim
/Mount-Wim
/Remount-Wim
/Cleanup-Wim
did you try Flash.ffu with a lower case F at the beginning?
Posted: Mon Jun 08, 2015 11:27 am
by Quiggers
tried both cases, runnig dism.exe from within the the unzipped folder,
the error led me to look into dism.exe which is where I noticed that the
Apply-Image option is not supported by my version of dism.exe
I have a windows 8.1 laptop at home, I'll try it on that tonight.
EDIT:
On re-reading the installation guidelines on MS Developers site it
seems to indicate that I should be running Windows10 technical preview on the host machine.
Is this my issue? Am I required to preview a PC OS to preview a Pi OS?
Posted: Mon Jun 08, 2015 6:47 pm
by GerritV
If you are in the directory where the presumably correct dism is located, add .\ in front of the command to be certain that you are executing the one in that directory and not from the Path setting.
Gerrit
Posted: Mon Jun 08, 2015 7:02 pm
by GerritV
Quiggers wrote:
EDIT:
No, there are multiple thread here that describe how to accomplish this on 7 or 8 or 8.1. You need the correct version of dism.exe, e.g. from the Windows 10 ADK or from a Windows 10 install iso. you only need the directory that includes dism, not a full install of the OS or ADK.
To execute the correct dism, either run it from the directory where it is located and use .\dism.exe .... or use the full path to where it is located, if .e.g you are running the command from the directory where you placed Flash.ffu
The version should report as 10074 or higher
Gerrit
Posted: Mon Jun 08, 2015 9:52 pm
by jtanner_msft
It should be noted that not all development features will fully work from within Visual Studio unless you’re running it on Windows 10 Technical Preview, but as Gerrit mentioned you don’t HAVE to use Win 10 TP to flash the SD card.
Posted: Tue Jun 09, 2015 5:53 pm
by John_
GerritV wrote:If you are in the directory where the presumably correct dism is located, add .\ in front of the command to be certain that you are executing the one in that directory and not from the Path setting.
Gerrit
Ah good tip!, added it to the initial post.
