No Picture Shown
Posted: Fri May 01, 2015 3:27 pm
by rausch88
Hy
After I installed my Pi with Windows 10 for IOT I was connecting it to my TV screen of the HDMI cable.
But I was getting no picture after some times I was searching for it in my Network and all was working good but it doesnt show something on the screen.
Do you know this problem and how it could be solved.
Thank you for your answers.
Re: No Picture Shown
Posted: Fri May 01, 2015 5:34 pm
by pranishk
Is there any chance you are using a slower SD card (eg Class 4); at this point we have a known issue where our launch application won't start on slower SD cards (which means the screen stays blank even after boot). At the moment the only workaround is to use a faster SD Card.
Pranish Kumar (
pranishk@microsoft.com)
Microsoft Corporation
Posted: Fri May 01, 2015 10:53 pm
by rausch88
Hi
It is an class 10 Micro SD Card.
So I dont think that ist the speed
Posted: Fri May 01, 2015 11:01 pm
by jtanner_msft
It could be that you need to try this:
My display doesn't look right, the screen appears cropped or stretched
This can happen on some monitors. To work around this force the board into DVI mode (vs. HDMI mode). You can read more about this here. Mount the SD card to a local PC and proceed to edit the file in the EFIESP partition. For example if the partition is mark as H drive, edit H:\config.txt by adding the following line.
hdmi_group=2 # forces DVI timing to be used
Posted: Sat May 02, 2015 3:39 am
by billyoungs
jtanner_msft wrote:It could be that you need to try this:
I tried, but still no screen displays.
Posted: Sat May 02, 2015 6:31 am
by Robpol86
You can try setting the resolution manually according to this:
https://www.raspberrypi.org/documentati ... fig-txt.md
Worked for me in this thread:
viewtopic.php?f=105&t=109037
