user7743
Joystick registers double
Mon May 20, 2019 3:10 pm
Hi all,
I am having some interesting behaviour with my sense hat. I wrote some code to be invoked on button press with the joystick. I noticed it seems to be being run twice. So, I took some code from teh getting started tutorial and modified it a touch.
If I run the code below. For every button press of the joystick I get the direction printed twice. Is this intended behaviour and I missed something? It seems far too consistent for a hardware fault IMO.
If this is intended, how do I react to the button press but only call the function once and not twice?
Here is the code...
from sense_hat import SenseHat
sense = SenseHat()
# Define the functions
def up():
    print 'up'
def down():
    print 'down'
def left():
    print 'left'
def right():
    print 'right'
def middle():
    print 'middle'
# Tell the program which function to associate with which direction
sense.stick.direction_up = up
sense.stick.direction_down = down
sense.stick.direction_left = left
sense.stick.direction_right = right
sense.stick.direction_middle = middle
while True:
    pass  # This keeps the program running to receive joystick events
scotty101
Re: Joystick registers double
Tue May 21, 2019 12:39 pm
I believe you can add a check to the callback function to tell whether the event was triggered by pressing the joystick or releasing it.
According to the tutorial (https://projects.raspberrypi.org/en/pro ... nse-hat/10)
def up():
    if event.action == 'pressed':
        print("Pressed Up")
Or the official documentation says that this is the syntax but I presume both work (https://pythonhosted.org/sense-hat/api/#joystick)
if event.action != ACTION_RELEASED:
alphanumeric
Tue May 21, 2019 7:56 pm
I did it this way, just a snippet of my full code.
Each button has three functions. Pressed, released, and held.
And there are 5 buttons, up, down, left, right and center.
from sense_hat import SenseHat, ACTION_PRESSED, ACTION_HELD, ACTION_RELEASED
sense = SenseHat()
def pushed_up(event):
    if event.action == ACTION_PRESSED:
       sense.low_light = False
def pushed_down(event):
       sense.low_light = True
sense.stick.direction_up = pushed_up
sense.stick.direction_down = pushed_down
sense.stick.direction_left = pushed_left
sense.stick.direction_right = pushed_right
sense.stick.direction_middle = pushed_middle
Return to “Astro Pi”
