Sense Hat % Humididty reads erroneously high?
Posted: Mon Aug 13, 2018 1:09 pm
I have two Sense Hats here that read too high a value for the % Humidity. Environment Canada lists it at 75%. My on the wall mechanical meter reads 70%. My BME680 reads it at 63%. My sense hat reads it at 86%. Swapped Sense Hats and it reads 88%. The higher the humidity is the bigger the error is. They quit often read above 100% when the actual humidity is around 80% to 90%.
Just redid my SD Card with the latest Raspbian and same deal. They read on the high side of what the actual humidity is. Any suggestions?
Is there a newer firmware for the sense hat, and can they be flashed?
import os
import time, datetime
from sense_hat import SenseHat, ACTION_PRESSED, ACTION_HELD, ACTION_RELEASED
sense = SenseHat()
sense.set_rotation(180)
sense.set_imu_config(False, False, False)
sense.low_light = True
s=(0.065) # scroll speed
w=(0) # color all white toggle
o=(140)
x=(2) #shutdown variable
# is really stick down
def pushed_up(event):
if event.action == ACTION_PRESSED:
# is really stick up
def pushed_down(event):
sense.low_light = False
#is really stick right
def pushed_left(event):
global w
global o
w = (255)
o = (255)
# is really stick left
def pushed_right(event):
global w
global o
w = (0)
o = (140)
def pushed_middle(event):
global x
x = (0)
sense.stick.direction_up = pushed_up
sense.stick.direction_down = pushed_down
sense.stick.direction_left = pushed_left
sense.stick.direction_right = pushed_right
sense.stick.direction_middle = pushed_middle
while True:
dateString = "%A %B %-d %-I:%M:%p"
msg = "It is %s" % (datetime.datetime.now().strftime(dateString))
sense.show_message(msg, scroll_speed=s, text_colour=(w, 255, 255))
t = sense.get_temperature()
t = round(t)
if t <= 0:
tc = [w, w, 255] # Blue
elif t > 0 and t < 13:
tc = [255, 255, w] # Yellow
elif t >= 13 and t <= 25:
tc = [w, 255, w] # Green
elif t > 25 and t <30:
tc = [255, o, w] # Orange
elif t >= 30:
tc = [255, w, w] # Red
msg = "and %sc" % (t)
sense.show_message(msg, scroll_speed=s, text_colour=tc)
h = sense.get_humidity()
h = round(h)
if h < 0:
h = 0
if h > 100:
h = 100
if h < 30:
hc = [255, w, w] # Red
elif h >= 30 and h <= 60:
hc = [w, 255, w] # Green
elif h > 60 and h < 80:
hc = [255, 255, w] # Yellow
elif h >= 80:
msg = "with %s%% Humidity" % (h)
sense.show_message(msg, scroll_speed=s, text_colour=hc)
p = sense.get_pressure()
p = round(p)
if p > 0 and p < 982:
pc = [255, w, w] # Red
msg = "- Barometer is Very Low @ %smb - Storm Watch" % (p)
sense.show_message(msg, scroll_speed=s, text_colour=pc)
elif p >= 982 and p < 1004:
pc = [255, 255, w] # Yellow
msg = "- Barometer is Low @ %smb - Possible Percipitation" % (p)
elif p >= 1004 and p < 1026:
pc = [w, 255, w] # Green
msg = "- Barometer is Mid Range @ %smb" % (p)
elif p >= 1026 and p < 1048:
pc = [w, w, 255] # Blue
msg = "- Barometer is High @ %smb" % (p)
elif p >= 1048:
msg = "- Barometer is Very High @ %smb - Expect Dry Conditions" % (p)
if x == 0:
sense.clear()
os.system("sudo shutdown now -P")
time.sleep(30)
elif x == 1:
sense.clear()
raise SystemExit
time.sleep(30)
# Last edited on Aug 10th 2018
# run sudo crontab -e
# add
# @reboot python3 /home/pi/THP.py &
