Joystick problems
Posted: Tue Jun 26, 2018 9:51 pm
by lukqw
Hi there!
I recently purchased the sense hat with the intent to play around with it a little bit, but I am having trouble with the joystick.
I have a raspberry pi 3 B running osmc v2018.06-1 and I also installed python-sense-hat. The problem is, that I can not, with any joystick program, get the joystick to work.
There is however a "Raspberry Pi Sense HAT Joystick" in /sys/class/input/ which I suppose means that the joystick is indeed being recognized.
One of the programs for example is this one:
from sense_hat import SenseHat
sense = SenseHat()
while True:
    for event in sense.stick.get_events():
        print("The joystick was {} {}".format(event.action, event.direction))
But it does not work.
I'm kinda stuck and don't know what to search for anymore, since no one seems to have this problem.
If anyone could help me out I'd really appreciate it!
Re: Joystick problems
Posted: Sat Jun 30, 2018 12:51 pm
by alphanumeric
It's not actually a joystick, not an analog one anyway. It's more of a hat switch, a 5 way switch. I'm using mine Ok in python using the sense hat code. https://pythonhosted.org/sense-hat/api/#joystick If that helps.
This partial code from my full file.
import os
import time, datetime
from sense_hat import SenseHat, ACTION_PRESSED, ACTION_HELD, ACTION_RELEASED
sense = SenseHat()
sense.set_rotation(180)
sense.set_imu_config(False, False, False)
sense.low_light = True
def pushed_up(event):
    if event.action == ACTION_PRESSED:
def pushed_down(event):
       sense.low_light = False
def pushed_left(event):
    global w
        w = (255)
def pushed_right(event):
    global w
        w = (0)
