Sense Hat Led Matrix issue
Posted: Fri May 11, 2018 8:13 pm
I am currently testing my Sense Hat and I do have an issue with the Led Matrix.
I wrote this code and tested it in the SenseHat Emulator : it turns on the led, one by one.
But when I test it directly with the SenseHat, I do have an entire line that turns on instead of a single led.
Here is the code used:
and the result with the Sense Hat (I've tested with and without the ribbon)
https://youtu.be/deGWcwmvW58
I've no idea where the problem come from ! Is my SenseHat broken ?
from time import sleep
from sense_hat import SenseHat
sense = SenseHat()
blue = (0,0,255)
red = (255,0,0)
x=0
y=0
while(x<8) and (y<8):
sense.set_pixel(x,y,blue)
sleep(0.5)
x=x+1
sense.clear(0,0,0)
if x>7:
x=0
y=y+1
