kramkroc
Use of PyEphem
Sat Nov 18, 2017 8:25 pm
Hi folks,
just wondering about the use of PyEphem in the Astro PI. The reading for the TLE is only valid for a period of time, so I wondered, in the depths of space (i.e. no network access) whether there was some way for an up to date reading to the supplied when a 3 hour program was to be kicked off?
Cheers in advance folks,
/Mark
Davespice
Raspberry Pi Foundation Employee & Forum Moderator
Re: Use of PyEphem
Mon Nov 20, 2017 9:20 am
Hi Mark
I'll be explaining this during the webinar (which your teacher will get an email about soon). But basically if you get chosen for space-flight a few minor modifications are made to your code to make it obey the Astro Pi MCP (Master Control Program). As part of those edits, if I see your code is using hard coded two-line element telemetry lines I update it to load the telemetry from a shared location which is kept up to date by our ground station in Switzerland.
So you can expect to be able to computer accurate ISS locations when your code runs.
I hope this helps!
Dave
kramkroc
Re: Use of PyEphem
Mon Nov 20, 2017 3:37 pm
Cheers (I am the "teacher", well, coderdojo mentor). That answer really helps us out!
Davespice
Re: Use of PyEphem
Tue Nov 21, 2017 9:04 am
Oh sorry! :)
divad
Re: Use of PyEphem
Wed Dec 06, 2017 1:50 pm
I have this error when I try to install ephem (sudo pip3 install pyephem) :
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -Ilibastro-3.7.6 -I/usr/include/python2.7 -c extensions/_libastro.c -o build/temp.linux-armv7l-2.7/extensions/_libastro.o
extensions/_libastro.c:3:20: fatal error: Python.h: Aucun fichier ou dossier de ce type
#include "Python.h"
compilation terminated.
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
Somebody can help me?
Thank you,
David.
Davespice
Re: Use of PyEphem
Thu Dec 07, 2017 3:20 pm
I normally just use
sudo pip3 install ephem
So ephem as opposed to pyephem.
You might find that installing these two packages helps
sudo apt-get install libc6 libc6-dev
Please also check out the Mission Space Lab webinar which explains how to use it;
https://www.youtube.com/watch?v=WYjaAZcWIPg&t=7760
DarrenPi
Re: Use of PyEphem
Tue Dec 19, 2017 2:48 pm
Hi
I am getting a similar install error. I have tried a few different solutions including the one suggested by Dave in the above post.
I have also tried the suggestions on this page https://raspberrypi.stackexchange.com/q ... or-python3 . As I am new to Raspberry Pi I don't know how to run the command below as root
python3 setup.py install
DarrenPi
Re: Use of PyEphem
Tue Dec 19, 2017 6:34 pm
Update
I have now successfully installed Ephem. I updated and upgraded raspbian, https://www.raspberrypi.org/documentati ... pdating.md
Return to “Astro Pi”
Who is online
