Two sense hats that ocasionally show over 100% humidity.
Posted: Mon Aug 07, 2017 12:07 pm
I have two sense hats that occasionally show over 100% humidity readings. It happens when the humidity is high, over 90%. Sometimes they read fine, then sometimes they read 114% etc? Condensation on the sensor maybe? I don't think it my code.
import os
import time, datetime
from sense_hat import SenseHat, ACTION_PRESSED, ACTION_HELD, ACTION_RELEASED
sense = SenseHat()
sense.set_rotation(180)
sense.set_imu_config(False, False, False)
sense.low_light = False
s=(0.065) # scroll speed
w=(0) # color all white toggle
x=(2) #shutdown variable
# is really stick down
def pushed_up(event):
if event.action == ACTION_PRESSED:
sense.low_light = True
# is really stick up
def pushed_down(event):
#is really stick right
def pushed_left(event):
global w
w = (255)
# is really stick left
def pushed_right(event):
global w
w = (0)
def pushed_middle(event):
global x
x = 0
sense.stick.direction_up = pushed_up
sense.stick.direction_down = pushed_down
sense.stick.direction_left = pushed_left
sense.stick.direction_right = pushed_right
sense.stick.direction_middle = pushed_middle
while True:
dateString = "%A %b %-d %-I:%M %p"
msg = "It is %s" % (datetime.datetime.now().strftime(dateString))
sense.show_message(msg, scroll_speed=s, text_colour=(w, 255, 255))
t = sense.get_temperature()
t = round(t)
if t <= 0:
tc = [w, w, 255] # blue
elif t > 0 and t < 13:
tc = [255, 255, w] # yellow
elif t >= 13 and t <= 27:
tc = [w, 255, w] # green
elif t > 27:
tc = [255, w, w] # red
msg = "and %sc" % (t)
sense.show_message(msg, scroll_speed=s, text_colour=tc)
h = sense.get_humidity()
h = round(h)
if h >= 30 and h <= 60:
hc = [w, 255, w] # green
msg = "with %s%% Humidity" % (h)
sense.show_message(msg, scroll_speed=s, text_colour=hc)
elif h > 60 and h < 80:
hc = [255, 255, w] # yellow
else:
hc = [255, w, w] # red
p = sense.get_pressure()
p = round(p)
if p < 985:
pc = [255, w, w] # red
msg = "- Barometer is Very Low @ %smb - Storm Watch" % (p)
sense.show_message(msg, scroll_speed=s, text_colour=pc)
elif p >= 985 and p < 1005:
pc = [255, 255, w] # yellow
msg = "- Barometer is Low @ %sm - Posible Percipitationb" % (p)
elif p >= 1005 and p < 1025:
pc = [w, 255, w] # green
msg = "- Barometer is Mid Range @ %smb" % (p)
elif p >= 1025 and p < 1050:
pc = [w, w, 255] # blue
msg = "- Barometer is High @ %smb" % (p)
elif p >= 1050:
msg = "- Barometer is Very High @ %smb - Expect Dry Conditions" % (p)
if x == 0:
os.system("sudo shutdown now -P")
elif x == 1:
raise SystemExit
