gustavjoh
Sense HAT display adds random pixels
Thu Aug 03, 2017 3:27 pm
Hi, I ran into a strange issue with my brand new Sense HAT, when I run the simple script below multiple times random pixels start to light up. I have been able to run more advance programs as https://projects.raspberrypi.org/en/pro ... -astronaut on it and then it works fine but i can still from time to time see flashing pixels. Could this be normal?
from sense_hat import SenseHat
sense = SenseHat()
red = (255, 0, 0)
green = (0, 255, 0)
blue = (0, 0, 255)
sense.set_pixel(1,1,255,0,0)
First time script was run:
Second time script was run:
Third time script was run:
Davespice
Contact: Twitter
Re: Sense HAT display adds random pixels
Thu Aug 10, 2017 8:32 am
Hmm, that should definitely not happen. You could add a clear command at the start of your code to help mitigate it;
sense.clear()
Are you over-clocking the Pi?
Can you post the output of these Terminal commands too?
uname -a
sudo vcgencmd version
Return to “Astro Pi”
