losthill
Sense Hat Error
Mon May 08, 2017 2:29 am
I meet an error when I test the Sense Hat," it cannot detect the RPI-sense FB device" as attached picture. How can I solve this problem ? Thanks.
Sense Hat.jpg (55.29 KiB) Viewed 4382 times
alphanumeric
Re: Sense Hat Error
Mon May 08, 2017 11:33 am
More info on what your trying to do would help. Posting your code/file your running may help too.
alphanumeric
Re: Sense Hat Error
Mon May 08, 2017 11:35 am
What OS and what version it is would help too.
losthill
Re: Sense Hat Error
Wed May 17, 2017 9:36 am
The OS is the latest vision raspbian-jessie. And some parts were tested OK and others were failed.
alphanumeric
Re: Sense Hat Error
Wed May 17, 2017 9:48 am
Open your file in idle2, then clip and past the contents here using the "Code" tags. Run it from idle and you'll get better error messages and a marker to the code that's creating the error. I test all my code in idle first, until it runs with no errors. Then give it a real world run.
alphanumeric
Re: Sense Hat Error
Wed May 17, 2017 9:52 am
Just so you know, the latest Raspbian already contains all the packages needed to run the sense hat. You shouldn't need to install anything extra. I can't tell what it is your doing from that screen shot alone.
Anne_Carlill
Contact: Website Facebook Twitter
Re: Sense Hat Error
Mon Oct 09, 2017 11:03 am
I had this problem too losthill
I meet an error when I test the Sense Hat," it cannot detect the RPI-sense FB device" as attached picture. How can I solve this problem ? .
It was solved by doing the following:
The R Pi is not recognising the Sense HAT. So go into the Terminal and alter config.txt with the instructions below:
sudo leafpad /boot/config.txt
Scroll down to the bottom of the config file and type:
dtoverlay = rpi-sense then 'Save' the config file and reboot your Pi.
Hope it works.
Anne
Davespice
Contact: Twitter
Re: Sense Hat Error
Mon Oct 09, 2017 12:53 pm
It will be one of two things, either a physical connection problem between the Sense HAT and the Pi or the EEPROM (a chip on the Sense HAT which announces what type of HAT it is) has become corrupted.
Following the advice above about config.txt should do the trick, but if not then check the HAT is pressed down well. I have seen some cheaper pin headers which have flat pins that cause this issue intermittently.
alphanumeric
Re: Sense Hat Error
Mon Oct 09, 2017 1:02 pm
Sense Hat connected directly to the Pi or mounted to something like the Black Hat Hac3r kit?
Rainbow pattern on the LED matrix on Pi Boot Up?
Return to “Astro Pi”
