FAPSI
Compass conflicts with Pitch and Roll - Reading of Zero
Sun Oct 09, 2016 2:42 pm
using the Sense Hat to log all the data that is coming from him in a loop, I just experienced that reading the compass
north = sense.get_compass()
results in a reading of 0 for pitch an roll afterwards:
orientation = sense.get_orientation()
pitch = orientation['pitch']
roll = orientation['roll']
If the compass is read out after pitch and roll, the second and all further readings of pitch and roll are exactly the same as for the first reading.
Has anyone experienced this before? It seems there is some "reset" missing in the get_orientation function.
Davespice
Contact: Twitter
Re: Compass conflicts with Pitch and Roll - Reading of Zero
Wed Oct 12, 2016 10:06 am
So the get_compass function makes a call to set_imu_config to disable everything but the compass.
In your code you would need to do something like this to compensate
sense.set_imu_config(True, True, True)
I hope this helps. See also this closed issue: https://github.com/RPi-Distro/python-se ... /issues/46
Return to “Astro Pi”
