I have raspberry Pi 2 with senseHAT stacked and all is working fine. But now I need use GPIO and others pins not in use by sensehat to control 2 motors. I saw that after stack HAT there is no way to insert wire because the hole pins are blocked. Is there a way to access the pins? If that is not possible then I will need to remove the HAT and use any other device that provide IMU and also allow use of GPIO.
Regards.
