Humidity sensor temperature: -58.0794029236 C
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 bc ...............?
10: 1b 00 75 32 9b be d6 a1 9e b2 00 00 00 00 80 a2 ?.u2??????....??
20: 87 00 00 00 00 00 00 03 ff 7f 15 ef fc 7f 18 ef ?......?.???????
30: 35 84 a9 21 00 c4 ff ff 39 03 dc d2 fd ff 2e 03 5??!.?..9????..?
I think regardless of where the user is, the temperature is unlikely to be -38C. I'd return the HAT and hope the replacement doesn't have the same issue.DougieLawson wrote:What is the altitude of the airfield (QFE)?
What is your altitude?
Have you corrected both readings to mean sea level (QNH)?
Thx - Both locations are anout 5 metres about sea level - looks like i'll be returning the Pi Hat to the distributor and try again ....DougieLawson wrote:What is the altitude of the airfield (QFE)?
So is there a known issue with the current set of new batched of Pi Hat ? As the Pi Hat was out of stock for some time ...ShiftPlusOne wrote:I think regardless of where the user is, the temperature is unlikely to be -38C. I'd return the HAT and hope the replacement doesn't have the same issue.DougieLawson wrote:What is the altitude of the airfield (QFE)?
Wow, you're living on the beach! So your readings should be entirely consistent with your local airfield.southernseas wrote:Thx - Both locations are anout 5 metres about sea level - looks like i'll be returning the Pi Hat to the distributor and try again ....DougieLawson wrote:What is the altitude of the airfield (QFE)?
yep ... life on the beach ..looking to get some weather data from hre http://www.thecoromandel.com/DougieLawson wrote:Wow, you're living on the beach! So your readings should be entirely consistent with your local airfield.southernseas wrote:Thx - Both locations are anout 5 metres about sea level - looks like i'll be returning the Pi Hat to the distributor and try again ....DougieLawson wrote:What is the altitude of the airfield (QFE)?
from sense_hat import SenseHat
sense = SenseHat()
t = sense.get_temperature()-102
pt = sense.get_temperature_from_pressure()
p = sense.get_pressure()
h = sense.get_humidity()
t = round(t, 1)
p = round(p, 1)
h = round(h, 1)
pt = round(pt,1)
print("Temperature: %s C" % t)
print("Temperature from Pressure: %s C" % pt)Pftt, I'm living at 3m, quite a few spots on the map around me are at zero .... waterproof case does sound like a good ideasouthernseas wrote:yep ... life on the beach ..looking to get some weather data from hre http://www.thecoromandel.com/DougieLawson wrote:Wow, you're living on the beach! So your readings should be entirely consistent with your local airfield.southernseas wrote: Thx - Both locations are anout 5 metres about sea level - looks like i'll be returning the Pi Hat to the distributor and try again ....
ideally a floating bouy
anyone know of a 3D plans for waterproof pi case with pi3 + baterry pack , e.g. 10000 mha + sense hat ?
humidity may be high
from time import sleep
sense = SenseHat()
while True:
if t == 0: t = sense.get_temperature()
else: sleep(0.1)
if p == 0: temp = sense.get_pressure()
else: sleep(0.1)
if h == 0: h = sense.get_humidity()
else: sleep(0.1)
if pt == 0: pt = sense.get_temperature_from_pressure
else: sleep(0.1)
t = round(t, 1)
p = round(p, 1)
h = round(h, 1)
pt = round(pt,1)
msg = "Temperature=%s, Pressure=%s , Humidity=%s, Temp_from_Pressure=%s" % (t,p,h,pt)
sense.show_message(msg, scroll_speed=0.05)
The zero reading is entirely a software thing. I think the python library just returns 0 when the reading is not ready.BGL wrote:I received my sensor from Germany today and it's reading the temperature as expected, it does occasionally return a '0' so have amended my script to account for this and have an RMA for my first sensor.
from time import sleep from sense_hat import SenseHat sense = SenseHat() while True: t = sense.get_temperature() if t == 0: t = sense.get_temperature() else: sleep(0.1) p = sense.get_pressure() if p == 0: temp = sense.get_pressure() else: sleep(0.1) h = sense.get_humidity() if h == 0: h = sense.get_humidity() else: sleep(0.1) pt = sense.get_temperature_from_pressure() if pt == 0: pt = sense.get_temperature_from_pressure else: sleep(0.1) t = round(t, 1) p = round(p, 1) h = round(h, 1) pt = round(pt,1) msg = "Temperature=%s, Pressure=%s , Humidity=%s, Temp_from_Pressure=%s" % (t,p,h,pt) sense.show_message(msg, scroll_speed=0.05)
[/quote]ShiftPlusOne wrote: The zero reading is entirely a software thing. I think the python library just returns 0 when the reading is not ready.
It's an HTS221. I've written a small C program to take the register dump and determine the temperature. It is entirely possible that I've made a mistake, so a second pair of eyes would be helpful.DougieLawson wrote:Has anyone considered that this number of failures is more likely to be a software bug than a hardware failure. I'd be looking at the code in the library whether it's handling 16-bit numbers correctly, whether it's converting unsigned values to signed values when it shouldn't be.
I wouldn't be blaming the hardware.
What sensor is it using?
$ i2cdump -r 0x00-0x3f -y 1 0x5f b
10: 1b 00 96 33 98 be 26 a2 9e b2 fb 00 18 00 80 9e ?.?3??&????.?.??
20: 87 00 00 00 00 00 00 03 e9 12 c3 e8 fe ff ab e8 ?......??????.??
30: 36 84 a9 21 00 c4 ed ff 49 03 bc d2 00 00 2d 03 6??!.??.I???..-?
