If yes I plan to use Arduino alongside Pi
thanks
Georgian_Geek wrote:If I use Sense HAT for my robot project, will I loose any GPIO pins?
If yes I plan to use Arduino alongside Pi![]()
thanks![]()
No. HATs are not stackable.Georgian_Geek wrote:I have one more question:
can I use motor controller board, something like this (picture below) with Sense HAT?
That's not a HAT.DougieLawson wrote:No. HATs are not stackable.
Hats are attached by connecting another header on top of the pi, with pins which go through the hat. Some of these headers have extended pins which poke out through the top of the HAT and allow you to connect other things.rpdom wrote:That's not a HAT.DougieLawson wrote:No. HATs are not stackable.
Does the Sense HAT have pins on top? If so, that board may work with it, as long as none of the GPIOs used by the board clash with those used by the Sense HAT.
If you have schematics for everything you're connecting and you're still not sure, I recommend waiting a little bit until you're comfortable with the theory. If you don't understand how things are connected and configured, you risk frying stuff.Georgian_Geek wrote:I have one more question:
ok. I get it now, but can't I just connect male jumper wires to Sense HAT's above female headers.ShiftPlusOne wrote:
I only see that sort of working if you only put the HAT halfway on, and I wouldn't recommend it. You'd be pushing up against the pins coming in from underneath the HAT.Georgian_Geek wrote:ok. I get it now, but can't I just connect male jumper wires to Sense HAT's above female headers.ShiftPlusOne wrote:
Hats are attached by connecting another header on top of the pi, with pins which go through the hat. Some of these headers have extended pins which poke out through the top of the HAT and allow you to connect other things.![]()
thanks
Oh, I thought you were going to have the hat attached properly and then trying to put male jumpers in through the top, which wouldn't work because that space would be occupied by the pins underneath.Georgian_Geek wrote:what do you mean by "put the HAT halfway on". I understood it so (see attachment below). is that right?
I will buy headers with extended pins, anyway.![]()
thank you for helping me!
