will.moindrot
Sense-HAT on Pizero
Thu Jan 07, 2016 9:41 am
Hi everyone,
I was wondering if the Sense HAT is compatible with Pizero? I have got mine working well with my Pi2, however for a mobile project I was looking to use with my Pizero and I'm finding that the HAT is not being recognised. The LED matrix stays lit once the kernel loads and any quick test scripts produces the error: "cannot detect rpi-sense fb device"
  • I have previously used a Pimoroni Scroll Phat display on the Pizero, through that enabling I2C.
  • Since installing the Sense Hat on the Pizero I have followed the software installation guide here: https://www.raspberrypi.org/learning/ge ... /software/
    (going an apt-get install and upgrade, installing sense-hat and doing a pip install of pillow).
  • After a reboot the led matrix stays on which differs to what I had previously seen on the Pi2
  • Writing a quick python script to display some text on the display (following: https://www.raspberrypi.org/learning/ge ... worksheet/) and then running gives the error above "cannot detect rpi-sense fb device"
  • I have tried to reseat the Sense Hat a couple of times but still no joy
The only thing I can think of (from my limited knowledge) that I haven't tried yet (damn day job!) is downloading a new copy of NOOBS to the SD card. But having said that I think I installed 10.5.0 when I got the Pizero last month. My Pi2's SD I think I installed Raspbian manually (not via NOOBS) so maybe that might be the problem?
Thanks, Will
W. H. Heydt
Re: Sense-HAT on Pizero
Thu Jan 07, 2016 3:14 pm
I can't see why it wouldn't be. Mine is mounted on a B+ and I've seen one mounted on an A+.
As regards OS...I use a directly loaded copy of Raspbian Wheezy (which I'm keeping that way, as that is what is in use on the ISS).
jdb
Thu Jan 07, 2016 3:33 pm
It *should* be compatible.
Can you post the output of sudo vcdbg log msg? This will tell us if the firmware looked for a HAT EEPROM.
Rockets are loud.
https://astro-pi.org
5uperdan
Thu Jan 07, 2016 6:07 pm
Hi Will
I had the same error message but
sudo rpi-update
followed by a reboot sorted it
Good luck
(viewtopic.php?f=104&t=127655)
will.moindrot
Thu Jan 07, 2016 9:53 pm
Thanks jdb, here's the info. I'll let you know if I get any joy in the meantime:
pi@raspberrypi:~ $ python sensetest.py
  File "sensetest.py", line 2, in <module>
    sense = SenseHat()
  File "/usr/lib/python2.7/dist-packages/sense_hat/sense_hat.py", line 36, in __init__
    raise OSError('Cannot detect %s device' % self.SENSE_HAT_FB_NAME)
OSError: Cannot detect RPi-Sense FB device
pi@raspberrypi:~ $ sudo vcdbg log msg
000947.706: HDMI:EDID version 1.3, 1 extensions, screen size 38x30 cm
000947.772: HDMI:EDID features - videodef 0x80 !standby !suspend active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
000947.857: HDMI:EDID found preferred DMT detail timing format: 1280x1024p @ 60 Hz (35)
000947.897: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
000947.936: HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
000947.973: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
000948.012: HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
000948.049: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
000948.086: HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
000948.128: HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
000948.217: HDMI:EDID standard timings block x 8: 0x714F 8180 0101 0101 0101 0101 0101 81C0
000948.265: HDMI:EDID found DMT format: code 21, 1152x864p @ 75 Hz (4:3) in standard timing 0
000948.314: HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 1
000948.375: HDMI:EDID found DMT format: code 85, 1280x720p @ 60 Hz (16:9) in standard timing 7
000961.387: HDMI:EDID parsing v3 CEA extension 0
000961.426: HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:no, yuv422:no, #native DTD:0
000961.471: HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
000961.509: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz (native)
000961.542: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
000961.573: HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
000961.603: HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
000961.662: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48|88|96 kHz, sample size: 16|20|24 bits
000961.678: HDMI:EDID found HDMI VSDB length 7
000961.702: HDMI:EDID HDMI VSDB has physical address 0.0.0.0
000961.723: HDMI:EDID HDMI VSDB supports AI:no, dual link DVI:no
000961.752: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:no 30-bit:no DC_yuv444:no
000961.770: HDMI:EDID HDMI VSDB max TMDS clock 165 MHz
000961.786: HDMI:EDID HDMI VSDB has no latency information
000961.827: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
000961.958: HDMI:EDID preferred mode remained as DMT (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz
000964.465: HDMI:Setting property pixel encoding to Default
000964.486: HDMI:Setting property pixel clock type to PAL
000964.506: HDMI:Setting property content type flag to No data
000964.525: HDMI:Setting property fuzzy format match to enabled
000979.066: gpioman: gpioman_get_pin_num: pin LEDS_RUNNING not defined
000979.089: gpioman: gpioman_get_pin_num: pin LEDS_NAND_ACTIVITY not defined
000979.111: gpioman: gpioman_get_pin_num: pin LEDS_USB_ACTIVITY not defined
000979.132: gpioman: gpioman_get_pin_num: pin LEDS_FATAL_ERROR not defined
000979.154: gpioman: gpioman_get_pin_num: pin LEDS_APP_OK not defined
000979.176: gpioman: gpioman_get_pin_num: pin LEDS_APP_FAILED not defined
000979.196: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_AUTH not defined
000979.219: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_UNAUTH not defined
000979.241: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_ON not defined
000979.263: gpioman: gpioman_get_pin_num: pin LEDS_DVI_ON not defined
000979.285: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_HPD_UP not defined
000979.307: gpioman: gpioman_get_pin_num: pin LEDS_REMOTE_CONTROL not defined
000979.327: gpioman: gpioman_get_pin_num: pin LEDS_ARM_CONTROLLED not defined
000985.325: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
000997.492: hdmi: HDMI:EDID version 1.3, 1 extensions, screen size 38x30 cm
000997.562: hdmi: HDMI:EDID features - videodef 0x80 !standby !suspend active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
000997.654: hdmi: HDMI:EDID found preferred DMT detail timing format: 1280x1024p @ 60 Hz (35)
000997.698: hdmi: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
000997.740: hdmi: HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
000997.780: hdmi: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
000997.822: hdmi: HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
000997.864: hdmi: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
000997.904: hdmi: HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
000997.950: hdmi: HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
000998.042: hdmi: HDMI:EDID standard timings block x 8: 0x714F 8180 0101 0101 0101 0101 0101 81C0
000998.095: hdmi: HDMI:EDID found DMT format: code 21, 1152x864p @ 75 Hz (4:3) in standard timing 0
000998.147: hdmi: HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 1
000998.213: hdmi: HDMI:EDID found DMT format: code 85, 1280x720p @ 60 Hz (16:9) in standard timing 7
001011.227: hdmi: HDMI:EDID parsing v3 CEA extension 0
001011.269: hdmi: HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:no, yuv422:no, #native DTD:0
001011.318: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
001011.359: hdmi: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz (native)
001011.395: hdmi: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
001011.430: hdmi: HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
001011.464: hdmi: HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
001011.527: hdmi: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48|88|96 kHz, sample size: 16|20|24 bits
001011.546: hdmi: HDMI:EDID found HDMI VSDB length 7
001011.575: hdmi: HDMI:EDID HDMI VSDB has physical address 0.0.0.0
001011.598: hdmi: HDMI:EDID HDMI VSDB supports AI:no, dual link DVI:no
001011.630: hdmi: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:no 30-bit:no DC_yuv444:no
001011.652: hdmi: HDMI:EDID HDMI VSDB max TMDS clock 165 MHz
001011.670: hdmi: HDMI:EDID HDMI VSDB has no latency information
001011.714: hdmi: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
001011.887: hdmi: HDMI:EDID preferred mode is updated to DMT (16) 1024x768p @ 60 Hz with pixel clock 65000000 Hz
001011.910: hdmi: HDMI: hotplug attached with HDMI support
001011.979: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001014.452: hdmi: HDMI: power_on to DMT mode XGA@60
001017.627: hdmi: HDMI: Action callback added to queue to happen at frame 2
001017.650: hdmi: HDMI: Action stop_3d_mode added to queue to happen at frame 2
001017.673: hdmi: HDMI: Action unmute added to queue to happen at frame 3
001017.698: hdmi: HDMI: Action cec_init added to queue to happen at frame 3
001067.542: *** Restart logging
001068.573: Read command line from file 'cmdline.txt'
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
001072.979: Loading 'kernel.img' from SD card
001312.234: Kernel trailer DTOK property says yes
001312.316: Loading 'bcm2708-rpi-b-plus.dtb' from SD card
001345.604: dtparam: audio=on
001348.081: dtparam: i2c_arm=on
001351.883: dtparam: arm_freq=1000000000
001353.118: Unknown dtparam 'arm_freq' - ignored
001353.143: dtparam: core_freq=500000000
001357.580: dtparam: uart1_clkrate=1000000000
001358.801: Unknown dtparam 'uart1_clkrate' - ignored
001358.817: dtparam: cache_line_size=32
001391.335: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
003020.609: vchiq_core: vchiq_init_state: slot_zero = 0x5bc80000, is_master = 1
003024.289: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
003028.412: gpioman: gpioman_get_pin_num: pin LEDS_RUNNING not defined
003028.438: gpioman: gpioman_get_pin_num: pin LEDS_NAND_ACTIVITY not defined
003028.461: gpioman: gpioman_get_pin_num: pin LEDS_USB_ACTIVITY not defined
003028.483: gpioman: gpioman_get_pin_num: pin LEDS_FATAL_ERROR not defined
003028.516: gpioman: gpioman_get_pin_num: pin LEDS_APP_OK not defined
003028.540: gpioman: gpioman_get_pin_num: pin LEDS_APP_FAILED not defined
003028.561: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_AUTH not defined
003028.585: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_UNAUTH not defined
003028.609: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_ON not defined
003028.632: gpioman: gpioman_get_pin_num: pin LEDS_DVI_ON not defined
003028.660: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_HPD_UP not defined
003028.684: gpioman: gpioman_get_pin_num: pin LEDS_REMOTE_CONTROL not defined
003028.707: gpioman: gpioman_get_pin_num: pin LEDS_ARM_CONTROLLED not defined
003029.106: TV service:host side not connected, dropping notification 0x00000002, 0x00000002, 0x00000010
pi@raspberrypi:~ $
will.moindrot
Thu Jan 07, 2016 10:33 pm
Hi 5uperdan,
That sounds about right - thanks for this. I have jumped the gun and just kicked off a reinstall of NOOBS (the same version as before though). So if it's still giving me trouble I'll try out the suggestions in yours and the thread you linked to. Thanks, Will
5uperdan wrote:Hi Will
sudo rpi-update
Good luck
5uperdan
Fri Jan 08, 2016 10:24 pm
Seems my fix wasn't a fix at all and it was random luck that my sense hat worked for one boot and stopped working again after that. Think i might need to check my soldering work!
000812.363: HDMI:EDID error reading EDID block 0 attempt 0
000813.626: HDMI:EDID error reading EDID block 0 attempt 1
000814.885: HDMI:EDID error reading EDID block 0 attempt 2
000816.142: HDMI:EDID error reading EDID block 0 attempt 3
000817.400: HDMI:EDID error reading EDID block 0 attempt 4
000818.658: HDMI:EDID error reading EDID block 0 attempt 5
000819.916: HDMI:EDID error reading EDID block 0 attempt 6
000821.174: HDMI:EDID error reading EDID block 0 attempt 7
000822.432: HDMI:EDID error reading EDID block 0 attempt 8
000823.689: HDMI:EDID error reading EDID block 0 attempt 9
000824.711: HDMI:EDID giving up on reading EDID block 0
000827.039: HDMI:Setting property pixel encoding to Default
000827.060: HDMI:Setting property pixel clock type to PAL
000827.080: HDMI:Setting property content type flag to No data
000827.100: HDMI:Setting property fuzzy format match to enabled
000841.418: gpioman: gpioman_get_pin_num: pin LEDS_RUNNING not defined
000841.441: gpioman: gpioman_get_pin_num: pin LEDS_NAND_ACTIVITY not defined
000841.463: gpioman: gpioman_get_pin_num: pin LEDS_USB_ACTIVITY not defined
000841.484: gpioman: gpioman_get_pin_num: pin LEDS_FATAL_ERROR not defined
000841.506: gpioman: gpioman_get_pin_num: pin LEDS_APP_OK not defined
000841.528: gpioman: gpioman_get_pin_num: pin LEDS_APP_FAILED not defined
000841.548: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_AUTH not defined
000841.571: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_UNAUTH not defined
000841.593: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_ON not defined
000841.615: gpioman: gpioman_get_pin_num: pin LEDS_DVI_ON not defined
000841.637: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_HPD_UP not defined
000841.658: gpioman: gpioman_get_pin_num: pin LEDS_REMOTE_CONTROL not defined
000841.679: gpioman: gpioman_get_pin_num: pin LEDS_ARM_CONTROLLED not defined
000863.634: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
000864.041: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
000865.308: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
000866.570: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
000867.832: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
000869.094: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
000870.356: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
000871.619: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
000872.881: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
000874.143: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
000875.405: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
000876.430: hdmi: HDMI:EDID giving up on reading EDID block 0
000876.464: hdmi: HDMI: No lookup table for resolution group 0
000876.482: hdmi: HDMI: hotplug attached with DVI support
000876.551: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state        instead
000876.925: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
000878.189: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
000879.452: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
000880.715: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
000881.978: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
000883.241: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
000884.504: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
000885.768: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
000887.031: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
000888.294: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
000889.320: hdmi: HDMI:EDID giving up on reading EDID block 0
000891.837: hdmi: HDMI: power_on to DMT mode VGA@60
000894.957: hdmi: HDMI: Action callback added to queue to happen at frame 0
000911.140: *** Restart logging
000912.147: Read command line from file 'cmdline.txt'
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p7 roo        tfstype=ext4 elevator=deadline fsck.repair=yes rootwait
000913.871: Loading 'kernel.img' from SD card
001145.920: Kernel trailer DTOK property says yes
001146.003: Loading 'bcm2708-rpi-b-plus.dtb' from SD card
001180.445: dtparam: audio=on
001182.990: dtparam: arm_freq=1000000000
001184.249: Unknown dtparam 'arm_freq' - ignored
001184.270: dtparam: core_freq=400000000
001188.737: dtparam: uart1_clkrate=800000000
001189.996: Unknown dtparam 'uart1_clkrate' - ignored
001190.011: dtparam: cache_line_size=32
001223.634: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
002799.958: vchiq_core: vchiq_init_state: slot_zero = 0x5bc80000, is_master = 1
002803.961: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state        instead
002807.770: gpioman: gpioman_get_pin_num: pin LEDS_RUNNING not defined
002807.796: gpioman: gpioman_get_pin_num: pin LEDS_NAND_ACTIVITY not defined
002807.820: gpioman: gpioman_get_pin_num: pin LEDS_USB_ACTIVITY not defined
002807.842: gpioman: gpioman_get_pin_num: pin LEDS_FATAL_ERROR not defined
002807.865: gpioman: gpioman_get_pin_num: pin LEDS_APP_OK not defined
002807.889: gpioman: gpioman_get_pin_num: pin LEDS_APP_FAILED not defined
002807.910: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_AUTH not defined
002807.935: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_UNAUTH not defined
002807.958: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_ON not defined
002807.981: gpioman: gpioman_get_pin_num: pin LEDS_DVI_ON not defined
002808.005: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_HPD_UP not defined
002808.027: gpioman: gpioman_get_pin_num: pin LEDS_REMOTE_CONTROL not defined
002808.049: gpioman: gpioman_get_pin_num: pin LEDS_ARM_CONTROLLED not defined
002808.440: TV service:host side not connected, dropping notification 0x00000002        , 0x00000002, 0x00000004
5uperdan
Fri Jan 08, 2016 10:39 pm
Is it coincidental that my sense hat seems to be recognised when i have a keyboard and mouse plugged in? Here is the log from a successful boot
000824.135: HDMI:EDID version 1.3, 1 extensions, screen size 128x72 cm
000824.200: HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
000824.263: HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 50 Hz (31)
000824.307: HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
000824.349: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
000824.387: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
000824.428: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
000824.516: HDMI:EDID standard timings block x 8: 0x3140 4540 6140 8180 0101 0101 0101 0101
000824.566: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz (4:3) in standard timing 0
000824.615: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz (4:3) in standard timing 1
000824.662: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz (4:3) in standard timing 2
000824.716: HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 3
000837.729: HDMI:EDID parsing v3 CEA extension 0
000837.767: HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:2
000837.811: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
000837.852: HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
000837.897: HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
000837.969: HDMI:EDID found DMT detail timing format: 1366x768p @ 60 Hz (81)
000838.007: HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz (native)
000838.043: HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz (native)
000838.076: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
000838.110: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
000838.142: HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
000838.176: HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz
000838.210: HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz
000838.242: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
000838.275: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
000838.309: HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
000838.340: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
000838.374: HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
000838.407: HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
000838.458: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16 bits
000838.476: HDMI:EDID found HDMI VSDB length 8
000838.501: HDMI:EDID HDMI VSDB has physical address 2.0.0.0
000838.520: HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
000838.549: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
000838.569: HDMI:EDID HDMI VSDB max TMDS clock 190 MHz
000838.594: HDMI:EDID HDMI VSDB content type support: game|cinema|photo|text
000838.617: HDMI:EDID found Video Capability DB length 2
000838.643: HDMI:EDID video capability: CE:3 IT:2 PT:0 QS:1
000838.681: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
000838.856: HDMI:EDID preferred mode remained as CEA (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz
000841.167: HDMI:Setting property pixel encoding to Default
000841.187: HDMI:Setting property pixel clock type to PAL
000841.208: HDMI:Setting property content type flag to No data
000841.227: HDMI:Setting property fuzzy format match to enabled
000855.545: gpioman: gpioman_get_pin_num: pin LEDS_RUNNING not defined
000855.571: gpioman: gpioman_get_pin_num: pin LEDS_NAND_ACTIVITY not defined
000855.594: gpioman: gpioman_get_pin_num: pin LEDS_USB_ACTIVITY not defined
000855.616: gpioman: gpioman_get_pin_num: pin LEDS_FATAL_ERROR not defined
000855.636: gpioman: gpioman_get_pin_num: pin LEDS_APP_OK not defined
000855.657: gpioman: gpioman_get_pin_num: pin LEDS_APP_FAILED not defined
000855.680: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_AUTH not defined
000855.700: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_UNAUTH not defined
000855.720: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_ON not defined
000855.741: gpioman: gpioman_get_pin_num: pin LEDS_DVI_ON not defined
000855.761: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_HPD_UP not defined
000855.784: gpioman: gpioman_get_pin_num: pin LEDS_REMOTE_CONTROL not defined
000855.807: gpioman: gpioman_get_pin_num: pin LEDS_ARM_CONTROLLED not defined
000877.771: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
000889.933: hdmi: HDMI:EDID version 1.3, 1 extensions, screen size 128x72 cm
000890.004: hdmi: HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
000890.075: hdmi: HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 50 Hz (31)
000890.123: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
000890.166: hdmi: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
000890.209: hdmi: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
000890.251: hdmi: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
000890.345: hdmi: HDMI:EDID standard timings block x 8: 0x3140 4540 6140 8180 0101 0101 0101 0101
000890.395: hdmi: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz (4:3) in standard timing 0
000890.447: hdmi: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz (4:3) in standard timing 1
000890.501: hdmi: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz (4:3) in standard timing 2
000890.569: hdmi: HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 3
000903.588: hdmi: HDMI:EDID parsing v3 CEA extension 0
000903.630: hdmi: HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:2
000903.679: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
000903.725: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
000903.772: hdmi: HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
000903.847: hdmi: HDMI:EDID found DMT detail timing format: 1366x768p @ 60 Hz (81)
000903.887: hdmi: HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz (native)
000903.924: hdmi: HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz (native)
000903.961: hdmi: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
000903.997: hdmi: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
000904.035: hdmi: HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
000904.072: hdmi: HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz
000904.108: hdmi: HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz
000904.145: hdmi: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
000904.180: hdmi: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
000904.215: hdmi: HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
000904.251: hdmi: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
000904.286: hdmi: HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
000904.322: hdmi: HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
000904.375: hdmi: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16 bits
000904.398: hdmi: HDMI:EDID found HDMI VSDB length 8
000904.427: hdmi: HDMI:EDID HDMI VSDB has physical address 2.0.0.0
000904.452: hdmi: HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
000904.486: hdmi: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
000904.507: hdmi: HDMI:EDID HDMI VSDB max TMDS clock 190 MHz
000904.537: hdmi: HDMI:EDID HDMI VSDB content type support: game|cinema|photo|text
000904.565: hdmi: HDMI:EDID found Video Capability DB length 2
000904.596: hdmi: HDMI:EDID video capability: CE:3 IT:2 PT:0 QS:1
000904.639: hdmi: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
000904.816: hdmi: HDMI:EDID preferred mode remained as CEA (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz
000904.836: hdmi: HDMI: hotplug attached with HDMI support
000904.908: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
000907.378: hdmi: HDMI: power_on to CEA mode 1080p50
000910.559: hdmi: HDMI: Action callback added to queue to happen at frame 2
000910.582: hdmi: HDMI: Action stop_3d_mode added to queue to happen at frame 2
000910.606: hdmi: HDMI: Action unmute added to queue to happen at frame 3
000910.634: hdmi: HDMI: Action cec_init added to queue to happen at frame 3
000990.628: *** Restart logging
000991.632: Read command line from file 'cmdline.txt'
001087.688: Loading 'kernel.img' from SD card
001319.857: Kernel trailer DTOK property says yes
001319.940: Loading 'bcm2708-rpi-b-plus.dtb' from SD card
001358.217: Loaded HAT overlay
001358.234: dtparam: audio=on
001374.013: dtparam: arm_freq=1000000000
001375.379: Unknown dtparam 'arm_freq' - ignored
001375.401: dtparam: core_freq=400000000
001380.360: dtparam: uart1_clkrate=800000000
001381.736: Unknown dtparam 'uart1_clkrate' - ignored
001381.752: dtparam: cache_line_size=32
001425.542: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
003016.631: vchiq_core: vchiq_init_state: slot_zero = 0x5bc80000, is_master = 1
003020.420: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
003021.063: gpioman: gpioman_get_pin_num: pin LEDS_RUNNING not defined
003021.086: gpioman: gpioman_get_pin_num: pin LEDS_NAND_ACTIVITY not defined
003021.107: gpioman: gpioman_get_pin_num: pin LEDS_USB_ACTIVITY not defined
003021.129: gpioman: gpioman_get_pin_num: pin LEDS_FATAL_ERROR not defined
003021.153: gpioman: gpioman_get_pin_num: pin LEDS_APP_OK not defined
003021.176: gpioman: gpioman_get_pin_num: pin LEDS_APP_FAILED not defined
003021.196: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_AUTH not defined
003021.218: gpioman: gpioman_get_pin_num: pin LEDS_HDCP_UNAUTH not defined
003021.243: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_ON not defined
003021.265: gpioman: gpioman_get_pin_num: pin LEDS_DVI_ON not defined
003021.288: gpioman: gpioman_get_pin_num: pin LEDS_HDMI_HPD_UP not defined
003021.311: gpioman: gpioman_get_pin_num: pin LEDS_REMOTE_CONTROL not defined
003021.332: gpioman: gpioman_get_pin_num: pin LEDS_ARM_CONTROLLED not defined
003021.695: TV service:host side not connected, dropping notification 0x00000002, 0x00000001, 0x0000001f
will.moindrot
Sat Jan 09, 2016 1:47 pm
Hi all, thanks to everybody who replied. Coming back to it this morning I managed to get it working on my Pizero:
Reinstalled Noobs 10.5.0, did apt-get upgrade and install, did rpi-update, and after reboot the matrix went off and could run my test program (found that did not have to install sense-hat or pillow as already there). So I think the rpi-update (that I think updates the firmware to newest version) did the trick.
Best, Will
Return to “Astro Pi”
