[pi@raspberrypi-nlPd7ZuAgA ~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.7-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #817 SMP PREEMPT Sat Sep 19 15:32:00 BST 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: BCM2709
[ 0.000000] cma: Reserved 8 MiB at 0x36800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 225280
[ 0.000000] free_area_init_node: node 0, pgdat 8085af80, node_mem_map b6036000
[ 0.000000] Normal zone: 1980 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 225280 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b5ffd000 s20608 r8192 d24448 u53248
[ 0.000000] pcpu-alloc: s20608 r8192 d24448 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 223300
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2709.boardrev=0xa01041 bcm2709.serial=0x69d98e7a smsc95xx.macaddr=B8:27:EB:D9:8E:7A bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 874604K/901120K available (5958K kernel code, 534K rwdata, 1648K rodata, 416K init, 757K bss, 18324K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xb7800000 - 0xff000000 (1144 MB)
[ 0.000000] lowmem : 0x80000000 - 0xb7000000 ( 880 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80775cd0 (7608 kB)
[ 0.000000] .init : 0x80776000 - 0x807de000 ( 416 kB)
[ 0.000000] .data : 0x807de000 - 0x80863af4 ( 535 kB)
[ 0.000000] .bss : 0x80866000 - 0x8092378c ( 758 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000031] Switching to timer-based delay loop, resolution 52ns
[ 0.000317] Console: colour dummy device 80x30
[ 0.002055] console [tty1] enabled
[ 0.002118] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.002218] pid_max: default: 32768 minimum: 301
[ 0.002582] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002649] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003977] Initializing cgroup subsys blkio
[ 0.004062] Initializing cgroup subsys memory
[ 0.004132] Initializing cgroup subsys devices
[ 0.004193] Initializing cgroup subsys freezer
[ 0.004267] Initializing cgroup subsys net_cls
[ 0.004380] CPU: Testing write buffer coherency: ok
[ 0.004499] ftrace: allocating 20207 entries in 60 pages
[ 0.053934] missing device node for CPU 0
[ 0.054015] missing device node for CPU 1
[ 0.054053] missing device node for CPU 2
[ 0.054088] missing device node for CPU 3
[ 0.054133] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.054179] [bcm2709_smp_prepare_cpus] enter
[ 0.054337] Setting up static identity map for 0x8240 - 0x8274
[ 0.113924] [bcm2709_boot_secondary] cpu:1 started (0) 16
[ 0.114362] [bcm2709_secondary_init] enter cpu:1
[ 0.114417] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.133911] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.134273] [bcm2709_secondary_init] enter cpu:2
[ 0.134305] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.153949] [bcm2709_boot_secondary] cpu:3 started (0) 16
[ 0.154205] [bcm2709_secondary_init] enter cpu:3
[ 0.154235] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.154329] Brought up 4 CPUs
[ 0.154435] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.154478] CPU: All CPU(s) started in SVC mode.
[ 0.155483] devtmpfs: initialized
[ 0.176047] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.176402] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.177561] pinctrl core: initialized pinctrl subsystem
[ 0.178389] NET: Registered protocol family 16
[ 0.184112] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.185277] bcm2709.uart_clock = 3000000
[ 0.185354] of_platform_populate failed: -22
[ 0.187577] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.187645] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.187825] Serial: AMBA PL011 UART driver
[ 0.187995] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.188542] bcm2835-mbox bcm2835-mbox: mailbox enabled
[ 0.255436] bcm2708-dmaengine bcm2708-dmaengine: DMA legacy API manager at f3007000, dmachans=0x7f35
[ 0.255544] bcm2708-dmaengine bcm2708-dmaengine: failed to get irq for DMA channel 13
[ 0.255612] bcm2708-dmaengine bcm2708-dmaengine: Initialized 8 DMA channels (+ 1 legacy)
[ 0.256412] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 0.256480] bcm2708-dmaengine bcm2708-dmaengine: dma_debug:0
[ 0.257205] SCSI subsystem initialized
[ 0.257478] usbcore: registered new interface driver usbfs
[ 0.257611] usbcore: registered new interface driver hub
[ 0.257796] usbcore: registered new device driver usb
[ 0.258484] raspberrypi-firmware raspberrypi-firmware.0: Attached to firmware from 2015-09-23 12:21
[ 0.285722] Switched to clocksource arch_sys_counter
[ 0.334751] FS-Cache: Loaded
[ 0.335163] CacheFiles: Loaded
[ 0.348206] NET: Registered protocol family 2
[ 0.349635] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.349830] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.350071] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.350227] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.350324] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.350715] NET: Registered protocol family 1
[ 0.351255] RPC: Registered named UNIX socket transport module.
[ 0.351309] RPC: Registered udp transport module.
[ 0.351347] RPC: Registered tcp transport module.
[ 0.351385] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.352381] bcm2708_gpio: bcm2708_gpio_probe 80802a68
[ 0.354250] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.370343] VFS: Disk quotas dquot_6.6.0
[ 0.370751] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.373279] FS-Cache: Netfs 'nfs' registered for caching
[ 0.374567] NFS: Registering the id_resolver key type
[ 0.374681] Key type id_resolver registered
[ 0.374720] Key type id_legacy registered
[ 0.377782] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.378044] io scheduler noop registered
[ 0.378101] io scheduler deadline registered (default)
[ 0.378495] io scheduler cfq registered
[ 0.380185] BCM2708FB: allocated DMA memory f6c00000
[ 0.380267] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.409773] Console: switching to colour frame buffer device 228x61
[ 0.427968] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[ 0.429260] vc-cma: Videocore CMA driver
[ 0.429367] vc-cma: vc_cma_base = 0x00000000
[ 0.429474] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.429590] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.429943] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.446651] brd: module loaded
[ 0.455660] loop: module loaded
[ 0.456847] vchiq: vchiq_init_state: slot_zero = 0xb6c80000, is_master = 0
[ 0.458787] Loading iSCSI transport class v2.0-870.
[ 0.459866] usbcore: registered new interface driver smsc95xx
[ 0.460075] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.660519] Core Release: 2.80a
[ 0.660615] Setting default values for core params
[ 0.660769] Finished setting default values for core params
[ 0.861278] Using Buffer DMA mode
[ 0.861368] Periodic Transfer Interrupt Enhancement - disabled
[ 0.861493] Multiprocessor Interrupt Enhancement - disabled
[ 0.861614] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.861718] Dedicated Tx FIFOs mode
[ 0.862164] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xb6c14000 dma = 0xf6c14000 len=9024
[ 0.862395] FIQ FSM acceleration enabled for :
[ 0.862395] Non-periodic Split Transactions
[ 0.862395] Periodic Split Transactions
[ 0.862395] High-Speed Isochronous Endpoints
[ 0.862720] dwc_otg: Microframe scheduler enabled
[ 0.862793] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80401108
[ 0.867543] WARN::hcd_init_fiq:413: FIQ ASM at 0x80401464 length 36
[ 0.872227] WARN::hcd_init_fiq:438: MPHI regs_base at 0xb789a000
[ 0.876933] dwc_otg bcm2708_usb: DWC OTG Controller
[ 0.881703] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 0.886492] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 0.891206] Init: Port Power? op_state=1
[ 0.895855] Init: Power Port (0)
[ 0.900748] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.905413] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.910087] usb usb1: Product: DWC OTG Controller
[ 0.914713] usb usb1: Manufacturer: Linux 4.1.7-v7+ dwc_otg_hcd
[ 0.919390] usb usb1: SerialNumber: bcm2708_usb
[ 0.925075] hub 1-0:1.0: USB hub found
[ 0.929905] hub 1-0:1.0: 1 port detected
[ 0.935005] dwc_otg: FIQ enabled
[ 0.935019] dwc_otg: NAK holdoff enabled
[ 0.935031] dwc_otg: FIQ split-transaction FSM enabled
[ 0.935071] Module dwc_common_port init
[ 0.935491] usbcore: registered new interface driver usb-storage
[ 0.940518] mousedev: PS/2 mouse device common for all mice
[ 0.946033] bcm2835-cpufreq: min=600000 max=900000
[ 0.951067] sdhci: Secure Digital Host Controller Interface driver
[ 0.955694] sdhci: Copyright(c) Pierre Ossman
[ 0.960630] mmc-bcm2835 mmc-bcm2835.0: mmc_debug:0 mmc_debug2:0
[ 0.965283] mmc-bcm2835 mmc-bcm2835.0: DMA channels allocated
[ 1.005914] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.010998] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.015820] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.020737] usbcore: registered new interface driver usbhid
[ 1.025372] usbhid: USB HID core driver
[ 1.030378] Initializing XFRM netlink socket
[ 1.035042] NET: Registered protocol family 17
[ 1.039888] Key type dns_resolver registered
[ 1.044930] Registering SWP/SWPB emulation handler
[ 1.045666] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.049572] mmc0: new high speed SDHC card at address aaaa
[ 1.050219] mmcblk0: mmc0:aaaa SL32G 28.7 GiB
[ 1.054106] mmcblk0: p1 p2
[ 1.069446] registered taskstats version 1
[ 1.074467] vc-sm: Videocore shared memory driver
[ 1.079152] [vc_sm_connected_init]: start
[ 1.084544] [vc_sm_connected_init]: end - returning 0
[ 1.125898] Indeed it is in host mode hprt0 = 00021501
[ 1.305823] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.310823] Indeed it is in host mode hprt0 = 00001101
[ 1.506124] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.510856] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.516495] hub 1-1:1.0: USB hub found
[ 1.521332] hub 1-1:1.0: 5 ports detected
[ 1.805766] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.906192] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.910904] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.918451] smsc95xx v1.0.4
[ 1.979835] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:d9:8e:7a
[ 2.075768] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 2.176530] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8179
[ 2.181362] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.186227] usb 1-1.2: Product: 802.11n NIC
[ 2.191041] usb 1-1.2: Manufacturer: Realtek
[ 2.195835] usb 1-1.2: SerialNumber: 00E04C0001
[ 2.242043] EXT4-fs (mmcblk0p2): recovery complete
[ 2.251819] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.256722] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.262915] devtmpfs: mounted
[ 2.268450] Freeing unused kernel memory: 416K (80776000 - 807de000)
[ 2.435797] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 2.558140] usb 1-1.3: New USB device found, idVendor=05ac, idProduct=12ab
[ 2.563180] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.568164] usb 1-1.3: Product: iPad
[ 2.573096] usb 1-1.3: Manufacturer: Apple Inc.
[ 2.578028] usb 1-1.3: SerialNumber: ae0489a2a4cef342ca86611459ed8a0d7a40a625
[ 2.675823] usb 1-1.4: new low-speed USB device number 6 using dwc_otg
[ 2.801383] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c05a
[ 2.807156] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.812484] usb 1-1.4: Product: USB Optical Mouse
[ 2.817582] usb 1-1.4: Manufacturer: Logitech
[ 2.828895] input: Logitech USB Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C05A.0001/input/input0
[ 2.835521] hid-generic 0003:046D:C05A.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-bcm2708_usb-1.4/input0
[ 2.935828] usb 1-1.5: new low-speed USB device number 7 using dwc_otg
[ 3.067952] usb 1-1.5: New USB device found, idVendor=046d, idProduct=c31c
[ 3.073577] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.080086] usb 1-1.5: Product: USB Keyboard
[ 3.086132] usb 1-1.5: Manufacturer: Logitech
[ 3.106723] input: Logitech USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:046D:C31C.0002/input/input1
[ 3.166232] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-bcm2708_usb-1.5/input0
[ 3.199490] input: Logitech USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:046D:C31C.0003/input/input2
[ 3.266253] hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Device [Logitech USB Keyboard] on usb-bcm2708_usb-1.5/input1
[ 3.447270] udevd[175]: starting version 175
[ 3.912921] bcm2708_i2c_init_pinmode(1,2)
[ 3.919655] bcm2708_i2c_init_pinmode(1,3)
[ 3.950989] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[ 3.976202] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 3.987625] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x3f204000 (irq 80)
[ 4.067952] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.161371] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 4.290969] usbcore: registered new interface driver r8188eu
[ 4.387094] random: nonblocking pool is initialized
[ 4.561385] ipheth 1-1.3:4.2: Apple iPhone USB Ethernet device attached
[ 4.566108] pcm512x 1-004d: Failed to reset device: -5
[ 4.566288] pcm512x: probe of 1-004d failed with error -5
[ 4.566682] pcm512x 1-004c: Failed to reset device: -5
[ 4.566825] pcm512x: probe of 1-004c failed with error -5
[ 4.570402] wm8804 1-003b: Failed to read device ID: -5
[ 4.570565] wm8804: probe of 1-003b failed with error -5
[ 4.609597] usbcore: registered new interface driver ipheth
[ 6.285539] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.616028] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.181743] i2c /dev entries driver
[ 11.571083] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 12.786490] MAC Address = c4:6e:1f:27:01:dc
[ 15.590174] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:2162644k SSFS
[ 18.075776] ------------[ cut here ]------------
[ 18.075836] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:303 dev_watchdog+0x27c/0x29c()
[ 18.075849] NETDEV WATCHDOG: eth1 (ipheth): transmit queue 0 timed out
[ 18.075857] Modules linked in: i2c_dev snd_bcm2835 snd_soc_tas5713 snd_soc_wm8804_i2c snd_soc_wm8804 snd_soc_pcm512x_i2c snd_soc_pcm512x ipheth regmap_i2c snd_soc_bcm2708_i2s regmap_mmio snd_soc_core snd_compress snd_pcm_dmaengine snd_pcm snd_seq joydev snd_seq_device evdev snd_timer r8188eu(C) snd spi_bcm2708 i2c_bcm2708
[ 18.075967] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G C 4.1.7-v7+ #817
[ 18.075975] Hardware name: BCM2709
[ 18.076010] [<80018440>] (unwind_backtrace) from [<80013e0c>] (show_stack+0x20/0x24)
[ 18.076029] [<80013e0c>] (show_stack) from [<80558548>] (dump_stack+0x98/0xe0)
[ 18.076050] [<80558548>] (dump_stack) from [<80026a4c>] (warn_slowpath_common+0x8c/0xc8)
[ 18.076070] [<80026a4c>] (warn_slowpath_common) from [<80026ac8>] (warn_slowpath_fmt+0x40/0x48)
[ 18.076089] [<80026ac8>] (warn_slowpath_fmt) from [<804a0a34>] (dev_watchdog+0x27c/0x29c)
[ 18.076112] [<804a0a34>] (dev_watchdog) from [<8007af30>] (call_timer_fn+0x40/0x1b0)
[ 18.076133] [<8007af30>] (call_timer_fn) from [<8007b624>] (run_timer_softirq+0x200/0x310)
[ 18.076152] [<8007b624>] (run_timer_softirq) from [<8002a260>] (__do_softirq+0x124/0x3d4)
[ 18.076167] [<8002a260>] (__do_softirq) from [<8002a8c8>] (irq_exit+0xcc/0x13c)
[ 18.076184] [<8002a8c8>] (irq_exit) from [<8006b614>] (__handle_domain_irq+0x8c/0xec)
[ 18.076202] [<8006b614>] (__handle_domain_irq) from [<8000933c>] (asm_do_IRQ+0x2c/0x30)
[ 18.076219] [<8000933c>] (asm_do_IRQ) from [<8055e1b4>] (__irq_svc+0x34/0x14c)
[ 18.076229] Exception stack(0x807dff20 to 0x807dff68)
[ 18.076243] ff20: 807fdcdc 00000000 00000000 00000000 807de000 807fcddc 00000001 ffffffff
[ 18.076258] ff40: 8085e6fc 807d8304 807fcd7c 807dff74 807dff68 807dff68 800109fc 80010a00
[ 18.076267] ff60: 60000013 ffffffff
[ 18.076285] [<8055e1b4>] (__irq_svc) from [<80010a00>] (arch_cpu_idle+0x30/0x4c)
[ 18.076305] [<80010a00>] (arch_cpu_idle) from [<8005fab8>] (cpu_startup_entry+0x20c/0x2c8)
[ 18.076325] [<8005fab8>] (cpu_startup_entry) from [<80553b34>] (rest_init+0x84/0x9c)
[ 18.076346] [<80553b34>] (rest_init) from [<80776ccc>] (start_kernel+0x388/0x3f4)
[ 18.076358] ---[ end trace e0b90baa042b050f ]---
[ 18.076375] ipheth 1-1.3:4.2: ipheth_tx_timeout: TX timeout]
