Pwl2
Accuracy of the temperature sensor
Tue Oct 27, 2015 11:35 pm
I was looking at acquiring 2 sense hats for a project. I was checking the tech specs on the swag store and the temp sensor is listed at "+/- 2 degC in the 0-65 degC range". Is this correct, it seems a bit wide? Is it a typo i.e should be 0.2 or is the sensor not accurate. As the sensors will be running and logging in 2 different places in the house and the results compared, they need to be accurate and close to identical. I can use other sensors e.g Adafruit but I am not that good at soldering and I need this running quickly. Btw, the hat(s) will not be mounted on the pi(s) so pi temperature is not a factor in the project.
Pwl2
Pwl2
ame
Re: Accuracy of the temperature sensor
Tue Oct 27, 2015 11:58 pm
It sounds like the sense hat is not appropriate for this project. How will you connect the hats to the Pi?
If you are trying to sense temperature at a distance the best place to start is with a Dallas DS18B20 one-wire sensor.
Pwl2
Wed Oct 28, 2015 11:35 am
Use a ribbon cable. I don't need distance, just avoiding the 'board heat' problem. If I need to use something else I will stick with an I2C solution as I need to learn that for my main project BUT your recommendation has been filed for future reference. Thanks. :D
Pwl2
Pwl2
Return to “Astro Pi”
