Woll
Minecraft_Map Sense Hat
Mon Oct 19, 2015 11:52 pm
I'm playing around with the Sense Hat and following the Minecraft Map trutorial on the Raspberry Pi Resources section. However, I can't get the program to work as I keep getting the following error messages.
File "/home/pi/minecraft-map/Minecraft-map Download.py", line 6, in <module>
mc = Minecraft.create()
File "/usr/lib/python3/dist-packages/mcpi/minecraft.py", line 171, in create
return Minecraft(Connection(address, port))
File "/usr/lib/python3/dist-packages/mcpi/connection.py", line 17, in __init__
self.socket.connect((address, port))
ConnectionRefusedError: [Errno 111] Connection refused
I started out typing the code as I want to learn coding and I got the error message. So I copied and pasted it from the Resources page, just to make sure I wasn't tpying anything wrong and I still get the same message.
I'm using the Pi 2B and the Raspbian Jessie OS if that's any help.
The full coded from the Resources page is written below.
from sense_hat import SenseHat
from mcpi.minecraft import Minecraft
from time import sleep
sense = SenseHat()
known_blocks = {}
def get_blocks():
    global known_blocks
    x, y, z = mc.player.getTilePos()
    y -= 1
    blocks = []
    for dz in range(z-3, z+5):
        for dx in range(x-3, x+5):
            b = (dx, y, dz)
            if b in known_blocks:
                block = known_blocks[b]
            else:
                block = mc.getBlock(dx, y, dz)
                known_blocks[b] = block
            blocks.append(block)
    return blocks
def lookup_colour(block):
    if block in colours:
        return colours[block]
    else:
        return white
def map_blocks_to_colours(blocks):
    return [lookup_colour(block) for block in blocks]
# blocks
air = 0
grass = 2
water = 9
sand = 12
# colours
white = (150, 150, 150)
green = (0, 150, 0)
blue = (0, 0, 150)
yellow = (150, 150, 0)
black = (0, 0, 0)
# block: colour
colours = {
    air: white,
    grass: green,
    water: blue,
    sand: yellow,
player_pos = 27
while True:
    blocks = get_blocks()
    pixels = map_blocks_to_colours(blocks)
    pixels[player_pos] = black  # denote player as black pixel
    sense.set_pixels(pixels)
Who ate all the Pi's? Who ate all the Pi's?
Boris Johnson, Boris Johnson,
Re: Minecraft_Map Sense Hat
Tue Oct 20, 2015 7:09 am
Do you have
auto lo
iface lo inet loopback
in your /etc/network/interfaces file
Woll
Tue Oct 20, 2015 5:22 pm
DougieLawson wrote:Do you have
auto lo
Thanks for the reply. I'm not sure. I'm using Raspbian Jessie so I thought everything was up to date. How would I add the above, using Terminal? I'm doing the command line course on
https://www.codecademy.com/courses/lear ... mmand-line
so hopefully I'll be able to add it. Which directory would I access /etc/network/interfaces from?
Tue Oct 20, 2015 7:31 pm
OK so what ports are in use? Is there something listening on port 4711 (that isn't Minecraft)?
sudo netstat -tlnp
should show you.
Woll
Tue Oct 20, 2015 7:58 pm
Thanks for the reply. This is what shows after doing sudo netstat -tlnp
I don't know what they are thou.
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      551/sshd
tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      668/cupsd
tcp6       0      0 :::22                   :::*                    LISTEN      551/sshd
tcp6       0      0 ::1:631                 :::*                    LISTEN      668/cupsd
Tue Oct 20, 2015 9:00 pm
Those are all normal, so your error is something else.
Woll
Tue Oct 20, 2015 9:17 pm
I saw this in another thread
sudo apt-get install libjpeg-dev
sudo pip-3.2 install pillow
But when I do the pillow, I get this.
$ sudo pip-3.2 install pillow
Requirement already satisfied (use --upgrade to upgrade): pillow in /usr/lib/python3/dist-packages
Cleaning up...
I've done a sudo apt-get upgrade today and I'm running Jessie. I would have thought everything would be working fine?
Return to “Astro Pi”
