chefdave
Sense hat in Fahrenheit
Fri Sep 25, 2015 2:34 pm
I know Celsius is a better way to display temperature, but unfortunately here in the US we don't "get it".
Is there a way to make the Sense Hat display Temperature in Fahrenheit ?
scotty101
Re: Sense hat in Fahrenheit
Fri Sep 25, 2015 3:01 pm
Yep just convert it.
temp = ((temp/5)*9)+32
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
andyk1
Tue Sep 27, 2016 6:39 am
Is there any way anyone can show me a line of code that uses this formula. I have searched and can not find a usable line of code for this. You can't just enter that into code and not run into errors.
vetzki
Tue Sep 27, 2016 9:18 am
you could use something like this:
def tofahrenheit(celsius):
    return( (celsius/5*9)+32 )
temp = tofahrenheit(sense.get_temperature())
print(temp)
jahboater
Tue Sep 27, 2016 9:35 am
andyk1 wrote:Is there any way anyone can show me a line of code that uses this formula. I have searched and can not find a usable line of code for this. You can't just enter that into code and not run into errors.
You most definitely can! Define "code"? What language?
You have been given some Python which is a very popular language for the purpose. I suspect you really mean "bash" the command interpreter (shell), in which case enclose the expression in (( and )).
The Pi and the sense hat are all about education.
So assuming you are using Python, try to modify the program (likely a .py) file, using the code given.
It should be really simple, and you will find it very satisfying when it works.
You will learn a lot which is what its all about!
Edit the Python file with nano.
andyk1
Tue Sep 27, 2016 2:07 pm
I suppose I should have been more clear. Yes writing in python 3.5.2
Trying to write for the Raspberry Pi Sensor Hat.
I manage to experiment and came up with the following:
t = sense.get_temperature() * 9/5 + 32
#or t = sense.get_temperature() * 1.8 +32
Both worked for my needs.
One other issue I am having is changing the color of the display... not background to a color say from:
-15 F to 65 F to be blue
66F to 85F to be green
86F to 120F to be red
On the sense-had display. I manage to get two colors to work, green and red but seems my code cancels out the colder blue code.
bensimmo
Tue Sep 27, 2016 3:38 pm
We would need your code for that.
copy and paste it all in code brackets faq.php?mode=bbcode#f2r1
personally if not at the command line then leafpad that RPF put in is much easier than nano.
scotty101
Tue Sep 27, 2016 4:47 pm
andyk1 wrote: One other issue I am having is changing the color of the display... not background to a color say from:
Be sure that you use the correct IF..ELIF..ELSE syntax in python.
For example (Modify for your own requirements)
if temp <= 65:
   displayBlue()
elif temp > 65 and temp <=85 :
   displayGreen()
else:
   displayRed()
andyk1
Tue Sep 27, 2016 5:50 pm
Let me try this again...
I will try and answer all your questions but first thank you all. For me as someone said would be easier to show you what I have so far. Yes am just learning.
# Project By Andy to create temp, hum, press,  wind,  rain, soil, uv , security cam's and other sensor.
from sense_hat import SenseHat
sense = SenseHat()
sense.set_rotation(180)
while True:
    t =  sense.get_temperature()  *  9/5  +  32 # changed to Fahrenheit. Works
#  t =  sense.get_temperature() *  1.8 + 32;    another way to read F temp
    p = sense.get_pressure()
    h = sense.get_humidity()
    t = round(t, 1)
    p = round(p, 1)
    h = round(h, 1)
#    if t > -15.0 and t < 64.9:  # can't get to read
#      tc = [0, 0, 100]  # Blue
#    else:
#      tc = [0, 100, 0]  # Green
    if t > 65.0 and t < 84.9:
    else:
        tc = [100, 0, 0]  # Red
#     if h > 85.0 and h < 120.0:  can't get to read
#        tc = [100, 0, 0]  # red
#      else:                                    can't get to read
#  msg = "T={0} P={0} H={0}"  .format ( t,p,h )
    msg = "T=%s P=%s H=%s"% (t , p, h)
#    sense.show_message(msg, scroll_speed=0.05, text_colour=[0,0,0], back_colour=bg)
    sense.show_message(msg, scroll_speed=0.07, text_colour=tc) # bg=background color
# todo. setup other sensors
# todo. setup day-night brightness
# todo .setuo to show on monitor also
hope I read this right.
As you can see parts of it works and parts don't. Not sure why I can't get this.
Tue Sep 27, 2016 6:36 pm
Edit your post and everywhere you've got [quote] change it to [code] and everywhere you've got [/quote] change it to [/code]
That will fix the ugly code formatting.
This is a doctor free zone.
andyk1
Tue Sep 27, 2016 7:02 pm
Thanks DougieLawson I did that
Paeryn
Tue Sep 27, 2016 7:30 pm
#    else:
    else:
I assume that should be t in the final commented out if statement, not h.
If they were not commented out then only the final if statement would take effect (either it's true or false section), it would overwrite whatever value was set in either of the other two before it.
If you want absolutely those ranges then something like
if -15 <= t <= 65:
elif 65 < t <= 85:
elif 85 < t <= 120:
else:
  tc = [100, 100, 100] # White
Here I've set tc to white if t is outside the specified range (to make sure it's set to something).
If you want always less than or equal to 65 to be blue, and always above 85 to be red with anything in between to be green then
if t <= 65:
elif t <= 85:
else:
She who travels light — forgot something.
bensimmo
It looks like you need to alter your If/Else into the format given above.
e.g.
if temperature < 65:
   temp_background_colour = [0, 0, 100]
elif temperature > 85 :
   temp_background_colour = [100, 0, 0]
else:
   temp_background_colour = [0, 100, 0]
Which check for cold so blue, hot so red and anything else must be good so green
bensimmo
Tue Sep 27, 2016 7:36 pm
oh and while you're at ti, you can test your code here quickly, https://trinket.io/sense-hat
you may need to put a sleep into your while loop?
andyk1
Wed Sep 28, 2016 4:57 am
Took all of your advice... thanks to everyone. Could not get some of your code to work for my purposes but trial and error I got this.
sense = SenseHat()
while True:
    t = round(t, 1)
    p = round(p, 1)
    h = round(h, 1)
    if t <= 65:
    elif t <= 80:
    else:
    sense.show_message(msg, scroll_speed=0.07, text_colour=tc) # bc=background color
I simplified it and does work.
Can someone show me how to print this to the monitor and sense-hat at the same time please? The print command doesn't work for me.
scotty101
Wed Sep 28, 2016 9:19 am
andyk1 wrote: Can someone show me how to print this to the monitor and sense-hat at the same time please? The print command doesn't work for me.
What about the print command doesn't work? Where do you expect the text to be displayed?
Are you running your program from the command line or from an IDE like IDLE?
andyk1
Wed Sep 28, 2016 11:14 am
I am using IDLE 3 Python 3.
What I am trying to do is have it display on the Pi sensor-hat and the Display monitor I have hooked up to the Rpi 3b via hdmi of course. Not sure why it does display on the sensor-hat but does not print to screen. Blank.
I am not at the terminal window so can't post the code. will in the morning. the code is actually a few posts up with the line:
print(t,p,h)
At the very bottom. No error code. No print to screen.
Need a cheat sheet for python 3 structure . Google is no help.
scotty101
Wed Sep 28, 2016 12:24 pm
Try the following
1. Open a instance of LXTerminal from the Raspberry Pi Menu
2. Type `python3`
3. At the python prompt type `print("Hello World")`
4. "Hello World" should be shown on the screen.
5. Type `quit()` to exit the python prompt.
The output of print will only be shown on a command prompt or similar terminal output. It won't appear as a popup or dialog on the screen for example.
Since you are using IDLE, the output of print should show up in the IDLE window that is probably called "Python 3.4.3 Shell"
Return to “Astro Pi”
