The instructions here https://www.raspberrypi.org/learning/ge ... /software/ are incomplete! The missing step is sudo pip-3.2 install pillow - without this python 3.2 will complain that it can't find the imaging library module.
Can someone please update the tutorial page?
Astro Pi tutorial problem
Neil Matthews
Lost count how many of As, Bs, APluses, BPluses, Pi2s and now a couple of Zer0s.
Get your E-paper HAT at www.percheron-electronics.uk/shop
- Raspberry Pi Engineer & Forum Moderator
- Location: The unfashionable end of the western spiral arm of the Galaxy
Re: Astro Pi tutorial problem
Sent a pull request.
Should be fixed now, thank you for reporting it.
I ran into this same issue (it still doesn't list the pip install pillow step)
Having done pip install pillow i got a subsequent error when running the test program
ImportError: No module named Image
Help - I'm stuck and don't know what to do
OK I worked it out - the instructions by the way are incorrect on the learning page https://www.raspberrypi.org/learning/as ... oftware.md because they miss the instruction to pip install pillow (I think the instructions elsewhere have been updated, but not on the 'learning' section)
My mistake was that I did the pip install of Pillow, but also added a 'import Image' into my code by mistake (I was copying from something else) - without the 'import image' in the code all was well.
Would be good to update https://www.raspberrypi.org/learning/as ... oftware.md because it is the thread I think that a lot of new users of the sensehat will follow.
Love the hat!! Just have to decide the best project to make now
