mattmiller
Error when trying examples with Python2
Sun Aug 30, 2015 4:19 pm
I've installed SenseHAT using
wget -O - http://www.raspberrypi.org/files/astro- ... install.sh --no-check-certificate | bash
When I run colour_cycle or rainbow.py using
sudo python colour_cycle.py
I get
self._pressure = RTIMU.RTPressure(self._imu_settings)
AttributeError: 'module' object has no attribute 'RTPressure
but error disappears when using
sudo python3 colour_cycle.py
Any ideas as to what's happening?
Matthew
B.Goode
Re: Error when trying examples with Python2
Sun Aug 30, 2015 5:05 pm
I can't find any specific evidence at http://pythonhosted.org/sense-hat/, but I think the chances are that the module you have downloaded and installed is designed to support and be compatible with Python3 scripts. So it may be working as intended.
(For the purposes of using imported modules and libraries, the only thing that python and python3 have in common is the first 6 characters of their names: in terms of implementation they are best regarded as 2 completely different languages.)
I believe the general policy of the Raspberry Pi Foundation is that new materials should be created using python3.
mattmiller
Sun Aug 30, 2015 9:26 pm
Before I look into this any further I'd just like to know if others get the same problem or is it just somehting up with my installation
ShiftPlusOne
Mon Aug 31, 2015 4:30 am
Either python2 or python3 would work.
That install script is deprecated and I don't know what the best way to undo what it has done is. The correct install instructions are on the pythonhosted page.
mattmiller
Mon Aug 31, 2015 6:45 am
Thanks for info
Could you get someone to pass that info onto the Swag store to get them to change their instructions
http://swag.raspberrypi.org/collections ... -sense-hat
mattmiller
Mon Aug 31, 2015 7:30 am
mm - it does seem a bit tricky
I tried
sudo apt-get purge sense-hat
followed by
sudo apt-get autoremove
which accoring to screen info seemed to remvoe everything (inc RTIMU libs) but when I reinstalled sense-hat - same error message :(
I then tried manual deleting any ref to RTIMU files from /usr/lib/python2.7/dist-packages and then doing a purge and install but still same problem :(
ShiftPlusOne
Mon Aug 31, 2015 7:47 am
Actually, I take that back. The script has been updated to do pretty much the same thing as what the instructions elsewhere say.
I'll look into it. Thanks
ShiftPlusOne
Tue Sep 01, 2015 8:16 am
I am having trouble reproducing this problem. Works as expected...
Could you please provide the the output of 'pip freeze' and' pip-3.2 freeze'?
mattmiller
Tue Sep 01, 2015 11:17 am
pip freeze
Warning: cannot find svn location for distribute==0.6.24dev-r0
Flask==0.10.1
Jinja2==2.7.3
MarkupSafe==0.23
PIL==1.1.7
Pyste==0.9.10
RPi.GPIO==0.5.11
RTIMULib==1.0
WebIOPi==0.7.0
Werkzeug==0.9.6
argparse==1.2.1
backports.ssl-match-hostname==3.4.0.2
certifi==14.05.14
## FIXME: could not find svn URL in dependency_links for this package:
itsdangerous==0.24
mcpi==0.1.1
numpy==1.6.2
oauthlib==0.7.2
picamera==1.10
pifacecommon==4.1.2
pifacedigitalio==3.0.4
pygame==1.9.1release
pygobject==3.8.2
requests==2.5.0
requests-oauthlib==0.4.2
rpi-ws281x==1.1.0
scratchpy==0.1.0
sense-hat==2.1.0
smbus==1.1
spidev==2.0
tornado==4.0.2
twython==3.2.0
unicornhat==1.0.2
ws2812==1.0.0
wsgiref==0.1.2
and
pip-3.2 freeze
Pillow==2.9.0
RPi.GPIO==0.5.11
RTIMULib==7.2.1
WebIOPi==0.7.0
mcpi==0.1.1
numpy==1.6.2
pifacecommon==4.1.2
sense-hat==2.1.0
unicornhat==1.0.2
ws2812==1.0.0
wsgiref==0.1.2
ShiftPlusOne
Tue Sep 01, 2015 11:47 am
Will need to get one of the python-ey people to take a look at it.
ShiftPlusOne
Tue Sep 01, 2015 11:49 am
One thing that jumps out is
RTIMULib==1.0 vs
RTIMULib==7.2.1
ShiftPlusOne
Tue Sep 01, 2015 11:53 am
Have you played around with the sense-hat prior to the launch? I am thinking you have an old version of RTIMULib which didn't have pressure sensor support on your system which is overriding the one provided by apt.
Edit: what does this say?
sudo find /usr -name "*RTIMU*.so"
mattmiller
Tue Sep 01, 2015 2:52 pm
I have tried out other gyro/accel boards in the past but first time with SenseHAT
/usr/local/lib/python2.7/dist-packages/RTIMU.so
/usr/lib/python3/dist-packages/RTIMU.cpython-32mu.so
/usr/lib/libRTIMULib.so
/usr/lib/python2.7/dist-packages/RTIMU.so
ShiftPlusOne
Tue Sep 01, 2015 2:54 pm
I think it's /usr/local/lib/python2.7/dist-packages/RTIMU.so that's causing you problems.
mattmiller
Tue Sep 01, 2015 3:16 pm
I've removed these two files
 /usr/local/lib/python2.7/dist-packages/RTIMULib-1.0.egg-info
and I seem to up and running :)
Thanks very much for your help :)
Matthew
ShiftPlusOne
Tue Sep 01, 2015 3:20 pm
No problem
Return to “Astro Pi”
