ShiftPlusOne
Re: Sense HAT now in commercial release
Sat Aug 29, 2015 10:09 am
No idea, don't have that case myself. You could just have the spacers connected to the hat itself, but not screw them to the pi.
W. H. Heydt
Sat Aug 29, 2015 4:48 pm
Hawksmoor wrote:Thanks for the info, I will give that a try. Should the Pi and Sense HAT still be able to fit into the official case once they spacers and screws are in place? I have seen a photo that suggests this is the case but I can't see how the Pi will clip into the bottom of the case if screws are through the mounting holes in the corners.
I've seen a SenseHAT on a Pi in the official case, but I didn't see how they did it (in part because I didn't look or ask...this was before the official case was released and I didn't know that was going to be an issue).
Perhaps Liz or Eben can enlighten us about how they did it.
(The one I saw was at the Maker Faire in May.)
plugwash
Sun Aug 30, 2015 6:30 pm
I suspect shiftplusone has it right, spacers screwed to the hat but either not screwed to the Pi at all or possiblly only screwed to the Pi in the two positions that are not used by the official case for mounting.
I'm pretty sure the former will work, not sure about the latter.
opi
Tue Sep 01, 2015 6:46 am
I received my Sense HAT today, and it only just doesn't fit into the official Raspberry Pi case. I had to use a knife to shave off a small amount of plastic from the inside of the top half of the case on the GPIO side. I only screwed in the spacers from the top of the HAT, and they almost felt like they clipped onto the longer of the case feet for the Pi board.
Attached images if people are interested.
Inside of top half of case
Top case frame attached
JSingleton
Fri Sep 04, 2015 3:20 pm
I've had a go with my Sense HAT and am liking it so far. I'm using a pibow coupé case so didn't need the spacers in the end as they don't fit it.
I've written up my experience of kicking the chips here: https://unop.uk/dev/raspberry-pi-sense-hat
These are some good official resources I found useful:
Computing4Kids.com
@shutdownscanner
unop.uk
WeebamNa
Sat Oct 17, 2015 9:19 pm
JSingleton wrote:I'm using a pibow coupé case so didn't need the spacers in the end as they don't fit it.
So the screws don't fit the coupé? I just got my Sense HAT from the Swag Store, and there were no screws, standoffs, or GPIO extenders.
tonygo2
Sun Oct 18, 2015 2:16 pm
I've got mine in but it was quite a fiddle.
You only need the two support posts on the long side near the joystick. The other long side is well supported by the GPIO pins. Leave out the bottom screws - they just get in the way of seating the Pi properly in the base. Leave out the SD card and white side piece by the GPIO pins as you put the Pi into the base with the other white side of the case loosely over the HDMI and other sockets. Make sure the Pi goes all the way down before fitting the other side.
It is a good, firm fit once in but you need both the red and white tops off to give full access to the joystick.
I got my Sense HAT from Pimoroni and it came with the spacers. If you need spacers then CPC have then for £1.99 and free postage.
http://cpc.farnell.com/ucreate/sense-ha ... st=SC13931
Best of luck - it's a great deal of fun once you get it working.
jb0815
Mon Nov 02, 2015 9:49 pm
Hi all,
I read about that freeze on boot problem with sense hat.
I have the same problem, but without the mentioned entry in /boot/cmdline.txt
What can it be else?
Regards
jb0815
ShiftPlusOne
Tue Nov 03, 2015 9:39 am
jb0815 wrote:Hi all,
Regards
jb0815
Could you please elaborate? I'm not familiar with any problems of that kind.
jb0815
Tue Nov 03, 2015 3:17 pm
Hi ShiftPlusOne
sorry replyed at the wrong place and at the moment I can't find the original post I mentioned.
It was because I registered in between reading and answering and got into the wrong page.
I try to find it, otherweise I will post my error messages here . But I've to retry it bevore.
Best Regards
jb0815
jb0815
Tue Nov 03, 2015 7:24 pm
Hi again,
I've found the original post, see below.
And ShiftPlusOne, find your reply at the end.
You remember ? There was a guy with a similiar problem.
I have the same output on my raspi , but I hav'nt theese entrys in cmdline.txt
AND:
Does the LED matrix stay lit up ? -> YES
Is the red LED on the pi itself constantly on? -> YES
Any idea ?
------------ snip -------------------------------
by michaelangelo » Fri Aug 28, 2015 12:08 pm
Cannot boot up with Sense HAT.
Just got my SenseHAT today and try on my RPi2 but freeze on bootup. Below is last few lines on my console:
Of course after rpi-update.
[ 4.170537] spi spi0.0: setting up native-CSO as GPIO 8
[ 4.237870] spi spi0.1: setting up native-CS1 as GPIO 7
[ 4.444530] rpi-sense 1-0046: Raspberry Pi Sense HAT firmware version 0
[ 4.493370] input: Raspberry Pi Sense HAT Joystick as /devices/virtual/input/input2
It freeze after input2.
SenseHAT lighted up in rainbow color on power up.
Can anyone help? Thanks.
Report this post
Permalink
by ShiftPlusOne » Fri Aug 28, 2015 12:32 pm
That's interesting. Are you able to pastebin all the output?
Does the LED matrix stay lit up or does it turn off?
ShiftPlusOne
Tue Nov 03, 2015 8:35 pm
jb0815 wrote:Hi again,
AND:
Any idea ?
Do you use, or have you ever used an additional screen that connects to GPIO? Do you have this problem with a clean, stock raspbian image?
jb0815
Wed Nov 04, 2015 10:00 am
Yes I have had played around with a touchscreen, but I commented out the driver in /etc/mudules.
Yesterday i installed a clean jessie, and the problem disappeared.
However I would like to understand what causes the problem.
ShiftPlusOne
Wed Nov 04, 2015 11:12 am
jb0815 wrote:Yes I have had played around with a touchscreen, but I commented out the driver in /etc/mudules.
Unfortunately, I have no way of knowing all the ways in which your install differed from stock. I expect there were changes made other than those in /etc/modules.
jb0815
Wed Nov 04, 2015 2:11 pm
Ok I thank you anyway.
At that point I think it's not worth to go deaper into the problem.
I will try to track the changes I make a bit more next time :-)
nitrologic
Wed Nov 11, 2015 3:51 am
Woot! I got mine Monday and it has been working like a charm.
I don't understand why the LED array uses white bezels, surely they should be black? I may try and make my own grill to try and improve black levels.
The temperature is reporting a bit warm, not sure if there is a calibration step or the hat surface is actually 32'C.
From GCC native coder point of view it would have been nice to have found the snake code when I first searched "github sense hat". The Python support feels a little too dominant / exclusive but I'm over that now :)
Return to “Astro Pi”
