OscarPi
GPIO Pins used by Sense HAT
Tue Aug 25, 2015 11:07 am
I am wondering which GPIO pins the Sense HAT uses, so I could use attach it to the Raspberry Pi with jumper wires and then use other GPIO pins.
Thanks!
scotty101
Re: GPIO Pins used
Wed Aug 26, 2015 8:56 am
Have a look for yourself
Schematics are here https://www.raspberrypi.org/wp-content/ ... T-V1_0.pdf
bonzadog
Re: GPIO Pins used by Sense HAT
Mon Dec 07, 2015 5:29 pm
i found the resultion of the pdf not very good and so difficult to read.
I feel that all HATs and external devices must include a text file with the GPIO pinning and
I2C/SPI addresses. Then using other sensors etc would be much easier.
Mon Dec 07, 2015 6:55 pm
bonzadog wrote:i found the resultion of the pdf not very good and so difficult to read.
Eh? Opened in Acrobat reader and magnified to 150% gives a perfect rendering.
This is a doctor free zone.
karrika
Mon Dec 07, 2015 6:56 pm
You can also see the pins at http://pinout.xyz/pinout/sense_hat
bonzadog
Tue Dec 08, 2015 2:06 am
@ karrika
Thanks for that - well worth looking at.
I feel that for every HAT the GPIO pins and I2C/SPI address should added to the documentation.
dim17300
Thu Oct 06, 2016 10:01 am
Hi there,
Did someone succeed in connecting with jumper wires the sense hat to the pi? Based on the datasheet i plugged the following pins (GPIO.Board configuration) :
- 3,5,19,21,23,27,4,6,16,18,22,24 and 28.
After i added the famous "dtoverlay=rpi-sense" on the config.txt, let's say after every reboot, sometimes i get the "IMU not initialized" and sometimes the sensors work perfectly... (Even if the lsmod responds the same modules as a raspberry with the shield directly plugged on it).
Thank you guys for your help
MikMod
Sat Jul 13, 2019 11:53 am
Hi.
For some reason, the pinout that works seems to be:
any ground pin
1, 2 - 3v and 5v power
3, 5 - BCM 2 and 3 - I2C
16, 18 - BCM 23 and 24 - Joystick
27, 28 - BCM 0 and 1 - EEPROM
bonzadog
Sun Jul 14, 2019 11:35 am
As I wrote the resolution is notz not good even with magnification. But I will try another read.
Return to “Astro Pi”
