theirry
pi Noir camera not detected but normal pi camera is.
Mon Jun 22, 2015 6:00 pm
when I do the usual command to take a picture with the cameras, it only takes a picture with the normal pi camera. Is this because I am only telling it to take a picture using that specific camera? how do I make it take a picture with noir?
I'm using the usual terminal method of taking the picture.
gordon77
Re: pi Noir camera not detected but normal pi camera is.
Mon Jun 22, 2015 6:32 pm
Noir or not they both appear the same to the pi
Mon Jun 22, 2015 6:55 pm
The #1 most common failure for the camera is the little SUNNY connector not being pushed fully home in the socket on the camera board. That's true for regular or NoIR cameras.
#2 most common failure is getting the ribbon cable the wrong way round.
#3 most common failure is not enabling the camera in /boot/config.txt
Least common failure is connecting the camera to the DSI connector rather than the CSI connector.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
theirry
Tue Jun 23, 2015 4:21 pm
I have checked and they both are working perfectly fine, but I strangely cant use the noir.
Tue Jun 23, 2015 5:09 pm
Has the NoIR camera ever worked?
Send it back to your supplier and ask for a replacement (or refund).
theirry
Tue Jun 23, 2015 8:14 pm
I will try take the normal camera out and use the noir first and see if it works. otherwise yes, I may do that.
theirry
Tue Jun 23, 2015 8:37 pm
just tested, it doesnt work, the red light is on but its not detected, even though the other one is
tomorrow I will try to use the other camera slot just in case.
rpdom
Tue Jun 23, 2015 8:50 pm
Which other camera slot? There is only the one camera connector.
Johnny5C
As Dougie said, check the sunny connector on the camera itself. It's prone to not being seated properly.
Simple check too.
Caught me out many times.
paulie
Tue Jun 23, 2015 9:09 pm
There is only one camera connector on the Pi.
The other similar connector is for the yet to be released official Pi Foundation screen.
(Unless you have the Compute Module breakout dev board, which I am led to believe supports two cameras).
https://www.raspberrypi.org/help/camera-module-setup/
It has been my custom to use Xeyes
Tue Jun 23, 2015 9:22 pm
theirry wrote:just tested, it doesnt work, the red light is on but its not detected, even though the other one is
If you do that the camera will NEVER work again, you may even ruin your Raspberry Pi.
theirry
Wed Jun 24, 2015 7:27 am
ok, thanks for the advice
theirry
Wed Jun 24, 2015 7:53 pm
ok, so I have put the noir in the right slot but its asking me to check the connections because it isnt working.. going to take off the hat once again..
theirry
Thu Jun 25, 2015 4:20 pm
Nope, cant detect infa red camera even in right slot....
Johnny5C
Thu Jun 25, 2015 9:27 pm
I had this problem. The sunny connector had popped out!
theirry
Fri Jun 26, 2015 8:36 pm
how to pop back in? xD
theirry
Fri Jun 26, 2015 8:37 pm
ok, its late at the moment so I'm going to try this tomorrow.
Sat Jun 27, 2015 9:07 am
theirry wrote:how to pop back in? xD
Take some static (esd) precautions (by wearing an earth strap or keeping contact with a MK1 big toe on an earthed cold water pipe). Take one MK1 thumb and one MK1 fore-finger. One on the back, one on the front. Pinch your finger and thumb together until you hear a soft click.
Grab a beer and celebrate a job well done.
theirry
Sat Jun 27, 2015 11:38 am
ok, looks like it was already in, still doesnt want to work.
Sat Jun 27, 2015 3:58 pm
theirry wrote:ok, looks like it was already in, still doesnt want to work.
It's worth a little bit of thumb & forefinger pressure even if it looks like it's fully home.
Return to “Astro Pi”
